BRAND NEW LED MARKER LIGHTS...2 red & 2 amber $200
SELL Spare parts, OEM, After Market, what ever that is Hummer related and for your Trucks
Skenth
Post by Skenth »
Brand new LED marker lights set bought from hummerpartsguy.com. for my hummer h1 Decided not replace due to rusted bolts on my truck...didn't want to go through the process. ASKING $200 FOR the set of 4. Lights are brand new in bags.
01-550-0495 MARKER LIGHT, REAR (RED) *BLACK* {LED} 01-550-0392 MARKER LIGHT, FRONT (AMBER) *BLACK* {LED} 2
Sonny Kenth
Re: BRAND NEW LED MARKER LIGHTS...2 red & 2 amber $200
Yea with any repair I basically have to plan on snapping all the bolts, I've come to terms with this,.
Lately (outta boredom ) I'm always lightly spraying engine area, and anything with rust sprays and try to keep things Lubed I guessed, antiseize is my best friend.
Skenth
Post by Skenth »
Problem is that I don't have the tools or the know how on how to fix a broken bolt...I really want to change em into LED but don't wanna risk breaking bolts. .
So might aswell sell em. Let me know if u or anyone u know what's them
Sonny Kenth
break the bolts
,rear-inside wheel well 3 per side
 front-behind the marker -2 per side, may have to remove bracket which is 3 screws ans 2 bolts per side
Honestly this job isn't as bad as it looks.....lol when I changed mine, and broke the first bolt, I lost it,lol
I swore/spit/ wondered why I even did this,.
Then after a day (of bitching) I realized I can use a drill 3/8" bit, wheat ever size close to shaft size
I drilled then heads off the bolts and pushed them in after heads drilled off, with a punch or Robertson screw driver.
Hold drill strong and be patient as you don't want to slip off the head and slide on paint,lol,.
For bolts/nuts
I bought little a plastic box that came with various size nuts and bolts at crappy tire, (10ish bucks)
Needed a drop light to be able to see in back easier, I had also little bit of ground issues as some wires/connections were sooooo corroded,
So basically took my time to clean ends, (some I replaced) but it's a good Sunday job,
Make sure you have access to another car, lol I forgot electric tape and did a quick trip after and lol to de-stress , heheh
Seriously do one at time and make work load less in head and you'll be shocked how quick can go,.
I put led's in last year and like the look myself,
ddgermann
Post by ddgermann »
Agreed... Let the bolts break if they must. Its a good chance to clean up the wiring too. The trick is putting in new bolts that will not rust. I just went through this and finally gave up and replaced the lighting for the whole truck. Before that I was replacing lights one at a time. Headlight assemblies disintegrating in my hands after the bolts broke off...that kind of thing.
You might actually have some fun doing it... this is part of owning an H1. Sometimes a really big part.
good luck Bud
Skenth
Post by Skenth »
Thanks guys for the insight. I had broken the 1st bolt and decided to call it quits and list the led bulbs for sale. Gave up too soon...haha.. I'll attempt to do it
Sonny Kenth
Lol EXACTLY , hehe after I broke that first one bolt I thought I was over head, (just so you know they all break) hehe and it don't take major pressure either for those babies to pop.
And then when I actually continued, realized it wasn't to bad of a job, and as stated ,got to clean up stuff while in there,.
I honestly don't think one bolt survived.(maybe one did)
