steering wheel control mod problem
- Zuba217
Re: steering wheel control mod problem
Is the viper and the pioneer together ? I mean ,,, do you used a bypass to control the factory alarm with the viper? If you did ,, Disconnect the wire of the bypass on the obdII connector and try it again !!! Good luck !!!
