H2 THIRD ROW BUILD
Pimped out your ride. Tell us about it.
BRUTE
H2 THIRD ROW BUILD
Post by BRUTE »
Well figured I'd share my little build with everyone on here.
Here's the vehicle for starters
Here are the subs ( 4 TSNS 15s )
Here are the batts ( 10 Exide Group 31s )
Here is the sub amp ( AB 1100.1 )
Here is the amp for the mids ( 2 AB 350.4 )
MIDS ( 12 neodymium 8s )
HIGHS ( 6 PEAVEY Tweeters )
BRUTE
Re: H2 THIRD ROW BUILD
Post by BRUTE »
Starting the build of the enclosure.
BRUTE
Post by BRUTE »
Getting the bracing ready
wow.. I am interested to see more.........
BRUTE
Post by BRUTE »
Front Baffle completed ( triple 1" )
BATTERY RACK
Test fitting first row of batts
Piecing together battery rack
Rack welded and completed (first row of batts only)
BRUTE
Post by BRUTE »
Test fitting amplifiers
BRUTE
Post by BRUTE »
The Port
TRIM PANEL ( front wall baffle )
Mounting the SUBS ( what a F$CKING PAIN....85lb+ each sub )
BRUTE
Post by BRUTE »
DONE !!
BRUTE
Post by BRUTE »
Now on to the DOORS
IMPORTANT NOTE.....doors are not finished yet. they still need to be cleaned up a bit around the corners and then wrapped in vinyl. Also insert covers are being made for cosmetic and protection purposes as well....
Doors have since been wrapped and finished..will post updated pics shortly
BRUTE
Post by BRUTE »
Hope you enjoyed the INITIAL build <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />
Now for an UPDATE......
Going to be changing things up.
Doors staying the same
Enclosure staying the same
NEW front baffle with subwoofer set up.
New AMPLIFIERS
New Batteries
Stay Tuned !
