H2 THIRD ROW BUILD
Pimped out your ride. Tell us about it.
BRUTE
Re: H2 THIRD ROW BUILD
Post by BRUTE »
been some time since I've updated this build thread what with winter and all.
so here goes
BRUTE
Post by BRUTE »
BRUTE
Post by BRUTE »
Designed the front baffle and then began the process of CNCing it one layer at a time.
Did an initial test cut out of 1/4mdf just to make sure all is good and that subs fit well.
Here is the 1/4" test cut baffle.
Then on to the fun part.
The baffle is going to be a total of 4" thick , 4 layers with each layer being 1".
BRUTE
Post by BRUTE »
Finished cutting the pieces of the port last night.
If need be more will be cut.
s0ulst3al3r
Post by s0ulst3al3r »
Wow!
2005 H2 SUT - 2007 Chopper
BRUTE
Post by BRUTE »
<div>A little test fitting to make sure its good to go.</div>
<div>For those unsure of whats being test fitted, its the second row seat conversion.</div>
<div> </div>
<div>Image</div>
<div> </div>
<div>Image</div>
BRUTE
Post by BRUTE »
Final piece of the puzzle came in recently.
I decided to change up the charging system.
NEW SET UP will consist of the following
-SINGLE 270a alternator for the 12v side of the vehicle and audio system
-3 370a alternators for the 14v portion of the audio system.
-QUAD ALT bracket
-3 external voltage regulators to adjust the charging of the 14v batteries
Beets
Post by Beets »
WOW looks awesome
[center]REMEMBER:[/center]
BRUTE
Post by BRUTE »
Thanks dude...
<div>NEW UPDATES</div>
<div> </div>
<div>Image</div>
<div> </div>
<div>Image</div>
<div> </div>
<div>Image</div>
<div> </div>
<div>Image</div>
<div> </div>
<div>Image</div>
