Looking for more power
Re: Looking for more power
[quote name='humrlvr][quote name='james7845] <P>I just finished installing a True Flow system' date=' I took it out for a spin and I have one word to say awesome' date=' the kick down has improved by at least 20% if not more, the engine sounds alive. I'll follow up in a week or so and let you know the extra mileage I'm getting, I should get about 1 mile to the gallon more. </P>[/QUOTE''] <DIV> </DIV><DIV>Hello James</DIV><DIV> </DIV><DIV>I'm interested In picking up this True Flow system to boost the horses In my H3!!! I live In Edm Ab, and I can't seem to find a dealer in my area that carries this brand. Would you or someone In this board know where I can locate such dealer???</DIV><DIV>Also would installing a Air Aid Throtle Body spacer, and a Cat-Back Exhaust Sys be a worth while investment to boost performance even further???</DIV><DIV> </DIV><DIV>P.S Have you figured out your fuel milage yet??? </DIV>[/QUOTE] <DIV> </DIV><DIV>You can also order them thru Canadian Tire via the Keystone catalog! As well if you are looking for a good offroad exhaust that will boost HP then use the Gibson Exhaust system also available thru Canadian Tire. And the Airaid throttle body spacer will definitely help mileage, but your driving style will be a greater determining factor than anything else. Also let me say it again SYNTHETIC OILS in everything will make a huge difference to mileage and reduced maintenance.</DIV><DIV> </DIV><DIV>Kevin</DIV>
- humrlvr
Thanks for the Input Guys... Much appreciated!!! <DIV> </DIV><DIV>James do you think that the spacer will interfere with the fit up of the Intake Sys? And Kevin which style of Gibson exhaust do you recommend? Split Or Single? As for the Synthetic Oils... Been added at 10,000 Km.</DIV><DIV>My Driving style is quite Conservative, I just need the extra Horses for those steep hill climbs, the occasional Log Jumping, and passing those Granny Drivers on the Highway without Pissing the guy off in the left lane while doing so... Grrrr</DIV><DIV> </DIV><DIV>Thanks Again Guys!!!</DIV><edited><editID>humrlvr</editID><editDate>2006-12-26 12:45:28</editDate></edited>
Go to this website: <a href="http://www.gibsonperformance.com/vehicle_products.asp" target="_blank">http://www.gibsonperformance.com/vehicl ... cts.asp</A> <DIV></DIV><DIV></DIV><DIV></DIV>You'll be able to see the three different styles they offer. I recommend the swept side exhaust since it follows the exact routing of your stock exhaust, so that way you won't have to worry about 'reshaping it' while enjoying your ride offroad!! <DIV> </DIV><DIV>Kevin</DIV>
