Hi all,
Another new member, from Northern BC and.............. without a Hummer.
I'm considering buying a Hummer, probably a H3.
All suggestions are welcome and hopefully I will be a member WITH a Hummer <img src='http://www.canadianhummerclub.com/forum ... lleyes.gif' class='bbc_emoticon' alt=':rolleyes:' />
Pete
New member
Re: New member
Welcome to our Family... All trucks are Great... depends on what you want to use it for and what you want to do... they all have their special uses as well as pros and cons...let us know and I am sure you will get lots of advice from the guys here
- Adanac
Re: New member
[quote name='dwaxman1' timestamp='1294843019' post='24115']
Thanks!!!!!!!!!!
Since a couple of weeks I'm the proud owner of a 2003 H2 and no regrets, not for a moment <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' />
But............. there's a problem with the air suspension. I know there are Hummer H2 Coil Spring Conversion Kits for sale in the States. Does somebody know if the kit is for sale in Canada?
Thanks!!!!!!!!!!
- JL
Re: New member
Congrats on the H2! I have a H3 but considering moving to a H2... Great trucks!
The spring kit is actually GM so any dealership can order that in for you!
- Khamul
Re: New member
Buying from the dealer though you will be paying double or more... Here is a link from Ebay:
http://motors.shop.ebay.ca/i.html?_nkw= ... m270.l1313
And an accessory site that I like is: http://www.teakatoys.com/Hummer_H2_Suspension_s/49.htm
On that ebay site are also the rear spacers if you ran your ride at full height. I installed the 2" spacer and I love the extra height it gives. You then want to consider the aftermarket keys from the front with either new shocks or the new extension brackets. T-Max and ready lift are 2 excellent its that you can get that will give you that extra height to match the rear.
Good luck!
Good luck!
