Chip problem H3
Andrew
Chip problem H3
Post by Andrew »
<FONT size=3>I have a 2006 H3 and have been having problems with the computer chip. In extreem cold situations, the chip gets condensation buildup which causes ice to form and the computer causes to fail the traction control system...the truck still runs but on reduced power, only 40kph top speed...this has happened twice to me, once at minus 38 and once at minus 36...anyone else having problems??? Apparently GM is working on a fix...heard anything??? Thanks Andrew<DIV></DIV><DIV></DIV>Desparate and shivering...</FONT>
boarral
Re: Chip problem H3
Post by boarral »
[QUOTE=Andrew] <font size="3">I have a 2006 H3 and have been having problems with the computer chip. In extreem cold situations, the chip gets condensation buildup which causes ice to form and the computer causes to fail the traction control system...the truck still runs but on reduced power, only 40kph top speed...this has happened twice to me, once at minus 38 and once at minus 36...anyone else having problems??? Apparently GM is working on a fix...heard anything??? Thanks Andrew
<div></div>
<div></div>Desparate and shivering...</font>[/QUOTE]
I do not know of any other H3 owners experiencing this problem. It sounds more like a fauly ECM than anything. You could push for them to replace yours and see if that solves it, even if it is something that they are working on.
humrlvr
Re: Chip problem H3
Post by humrlvr »
<P>I've never heard of this happening either!!!</P><DIV>Owned my H3 since Aug 05, Washed my engine compartment in warm and cold conditions, not once did i have any starting or any other problems for doing so.</DIV><DIV>I would say you have a faulty ECM/PCM also... Possibly due to a crack in the housing, or it's not sealed properly!!!</DIV><DIV> </DIV><DIV>Do you park your truck in a heated garage?</DIV>
rdeleau
Re: Chip problem H3
Post by rdeleau »
I have owned my H3 since Feb 06 and have not had any problems with computer chips in extreme weather
