H2 won't start ,stalls. key stuck. Stuck in park
dbot
Post by dbot »
<DIV>This is an update from a previous posting - useful information if you have a problem.</DIV><DIV> </DIV><DIV>For those with H2's. There are three problems that appear to occur rather often. These are: </SPAN></SPAN>
The key will not come out of the ignition and therefore not allow you to park the truck. </SPAN>
The Truck will not shift out of PARK resulting in your inability to move or even easily tow the truck. <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></SPAN></DIV><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">The truck either discharges its battery when the key is removed and/or the truck will not crank over and/or the truck will start and then just stall again.</SPAN></SPAN>
Needless to say when any of these happen it is VERY aggravating. </SPAN>
There are some solutions to these problems to get you out of a bind. It is also pretty easy to fix the truck. Some can be done with no parts, the other needs a special part that cost about $40 at the dealership. <o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Tool list<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Emergency tools-<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">For emergencies all you need is a Phillips screw driver. KEEP THIS TOOL IN YOUR TRUCK AT ALL TIMES. I suggest you buy a uni-tool and keep it in the truck.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">It is also suggested to keep a small drill bit - 1/8 inch<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Repair tools-<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Phillps screw driver (the same as used for emergencies)<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">An allan wrench set<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">A knife<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Some tape or preferably some small butt splices and a crimper<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Some 24 ga. Stranded wire<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">
Problem - I Cant get the key out of the ignition!<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Here is the procedure: </SPAN></SPAN>
KEY PROBLEM emergency extraction<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">For the key problem, you have two options. The first is to remove the bottom part of the steering wheel column cover. The second is to drill a small hole in the cover in a specific place (dont worry the hole is on the bottom and you cant see it). The steering wheel column cover is the gray-black thing that covers the steering column between the wheel and the dash. It tilts up and down with the steering wheel.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">If you dont have the drill bit here is how to get the cover off:<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">
Put the steering wheel tilt to the highest position.<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Remove the steering wheel tilt knob by pulling it straight out.<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Press the seam of the top and bottom plastic pieces of the cover inwards. You need to press hard enough to cause them to deflect enough to release the locking tabs that are on the inside  </SPAN>which hold the halves together. Use this procedure on all sides, one at a time. They WILL come apart. If you cant get them apart this way then you can break the part but it will cost you about $100 to get replacement parts.<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">If you have a drill bit (preferred method):<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Put the steering wheel to the full up position:<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Look under the steering wheel on the right side and look for an oval blemish in the plastic. This blemish is the spot where a plug  </SPAN>was put into the plastic mold resulting in an imperfect surface finish.<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Use the drill bit to bore a hole into the exact dead center of the oval. You can be off center a bit but try to keep it close to center. Once the hole is drilled adjust the drill angle so that you can insert the drill it straight up (rather than perpendicular to the plastic which is a curved surface.<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><?:namespace prefix = v ns = "urn:schemas-microsoft-com:vml" /><v:shape id=_x0000_t75 stroked="f" filled="f" path="m@4@5l@4@11@9@11@9@5xe" o:preferrelative="t" o:spt="75" coordsize="21600,21600"><v:stroke joinstyle="miter"></v:stroke><v:ulas><v:f eqn="if lineDrawn pixelLineWidth 0"></v:f><v:f eqn="sum @0 1 0"></v:f><v:f eqn="sum 0 0 @1"></v:f><v:f eqn="prod @2 1 2"></v:f><v:f eqn="prod @3 21600 pixelWidth"></v:f><v:f eqn="prod @3 21600 pixelHeight"></v:f><v:f eqn="sum @0 0 1"></v:f><v:f eqn="prod @6 1 2"></v:f><v:f eqn="prod @7 21600 pixelWidth"></v:f><v:f eqn="sum @8 21600 0"></v:f><v:f eqn="prod @7 21600 pixelHeight"></v:f><v:f eqn="sum @10 21600 0"></v:f></v:ulas><v:path o:connect="rect" gradientshapeok="t" o:extrusionok="f"></v:path><o:lock aspectratio="t" v:ext="edit"></o:lock></v:shape><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Once you have the hole drilled or you have the cover off:<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">There is a gold /silver button at the bottom of the steering wheel assembly that is either in direct line with the hole you drill or can be seen just behind and under the key. This button needs to be pushed up. Once pushed they key will come out.<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">If you have the drill hole you can use a tooth pick, paper clip or the drill bit to push the button. The nice thing is that the button is in direct line with the hole so you dont have to fish around very much. You can feel when you are pushing the button as it has about of travel and has a weak spring trying to push back.<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Now that the key is out, what next?<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">The problem will still exist next time you shut off the truck so keep the cover off or keep the drill bit handy.<BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">To fit the cause the of the problem you need to do the work described in the next section.<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">I cant get the truck out of park!<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Park Problem emergency procedure<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">This is a more serious problem as the truck is totally immobilized. You will have to do something if you want to get to where you are going. </SPAN></SPAN>
Fortunately, the solution is very easy. Note that The park problem can occur at the same time as the key problem so you may have to do both to get out of a bind . The repair of the shifter as described below will fix both problems.</SPAN><BR style="mso-special-character: line-break"><BR style="mso-special-character: line-break"><o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Here is the procedure<o:p></o:p></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">
Open the center console glove box and using the Phillips screw driver, remove the 4 screws that hold the center console "glove box" in place. The box is the tub right under the flip up door. <o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Remove the tub then stick you hand into the hole toward the shifter. While jiggling the shifter feel where the bottom of the shifter goes. Somewhere near the bottom, you will feel a round mushroom shaped thing, with the round part facing the PASSENGER SIDE. If you press on this, the shifter can now be shifted out of park using the regular method. You need to hold the button down when you want to shift out of park. The lock is only for park so all other gears are ok from this point on. Remember- every time you go to park position, the shifter will lock and you need to access the button each time to get out of park.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN>
What is the cause of the problem? </SPAN>
One frequent cause is a broken wire that goes to the shifter (the break is located in the center console). These wires control both the key removal and the parking lock. If you have either of these problems then have the cable checked or you can fix it your self as indicated below:<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Shifter stuck or key stuck repair<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Put the parking brake on<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Make sure the engine is off<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Put the shifter into 1 (farthest back position)<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Remove the shifter handle. To do this you need to loosen the allan screw (it is actually a torx screw but an allan wrench will work fine)<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">There is a screw on the front of the shifter that needs to be loosened <o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Pop the shifter console off the center console. There are 4 very hard to release metal clips that hold the shifter cover on. To release, you need to pull straight up on the shifter cover. Beware, you might break the plastic around the clips so be careful. The cover does come off perhaps with a lot of effort. If you are worried about breaking it go to a dealer for the repair.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Once the cover is off you will see a cable and connector near a mushroom shaped button. This button is the one you pressed to release the shifter from park. Either the connector is off or the wires to the connector are broken due to the flex back and forth that occurs during movement of the shift lever.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Find which wire is broken and fix it. It is preferable to use a small gauge, highly flexible wire  </SPAN>to extend the harness to connector cable length. It is also preferable to use butt splices rather then solder joints.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Test it and then put everything back together.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Problem<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">I start my truck and it stalls immediately<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">OR<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">The truck just turns over but will not start<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">OR<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">I turn the key and truck wont turn over<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">OR<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">I took the key out last night and the truck batteries are dead in the morning but I did not leave a light on, nor was there anything plugged in the lighter or accessory jacks<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">The problem is most likely a defective ignition switch. You will need to get a new one. The part number is GM# 15242754.  </SPAN>It is a common GM part and most dealers will carry it as a stock item. Cost is about $40.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Procedure:<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Remove the negative connection to the truck battery<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Remove the bottom cover of the steering wheel column cover as described in the stuck key problem procedure<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">The key switch assembly can be seen on the bottom right side of the steering column.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">You need to unplug the switch and then press in the spring loaded tabs that hold the switch in place to slide it out. There are several cables that may have to be moved around a bit but DO NOT UNPLUG THE LITTLE WIRES THAT GO TO THE TOP OF THE COLUMN since it you do so, the truck will think this is a theft attempt and set the security alarm.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"></SPAN></SPAN><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Once the switch is out,  </SPAN>get the new switch and make sure the gear of the new switch is in the  </SPAN>same position as the one that was removed.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Put the new switch into the proper position and plug in the connector<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Hook up the battery <o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Test that the switch works. If the gear is in the wrong position, the key either wont come out or the key will not move to the start position (the spring loaded start position). In either of these cases you need to remove the switch and re-position the gear.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Put the bottom cover back on the steering wheel column. Be sure to have the pieces aligned properly as it you dont, you can screw up the locking tabs. <o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt">Done.<o:p></o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p> </o:p></SPAN></SPAN></P><P =Msonormal style="MARGIN: 0in 0in 0pt"><o:p><FONT face="Times New Roman" size=3> </FONT></o:p></P>
