Idler and pitman arm??
- SELWA
Any one have any?? I need one of each to pass the saftey for my 95 H1<DIV> </DIV><DIV>I'm wondering if I should just flatbed (CAA) it to my place from Barrie and fix it myself!!</DIV><DIV> </DIV><DIV>What do you think??</DIV><DIV> </DIV><DIV> </DIV><DIV> </DIV><DIV> </DIV>
- 97hmcs
Re: Idler and pitman arm??
I've been getting these from the dealer, and they usually have them in stock. It's a fairly common "wear" item, so they tend to stock them. It's a pretty easy fix to replace these, but you will need a pickle fork ball joint seperator and a pitman arm puller (another type of joint seperator).<DIV> </DIV><DIV>Are they so worn that you can't drive it home? How far are you going?</DIV><DIV>Last year I went to the THCI Moab event in September, and ended up driving 2100 km back home on a badly worn idler arm. It got to the point that I couldn't exceed 90 km/hr due to the shimmying of the front end, but got home nonetheless. </DIV><DIV> </DIV><DIV>Robert</DIV><DIV>97 TD wagon</DIV><DIV> </DIV>
- SELWA
Looks like I was able to get some better pricing. I'll be seeing the H1 on Saturday and hopefully can get the parts and have the saftey done and ownership changed and drive it home finally.<DIV> </DIV><DIV>I called London Hummer and the prices they gave me were 125 for a pitman and 239 for a idler arm? They must be on crack!</DIV>
- Injunfarian
- CHC President
Did you try Phil I just got my pitman replaced there I'm sure he has some instock and definately good prices!!!!
Hey Selwa, I can get them, here is the following list <DIV> </DIV><DIV>Upper Ball Joint $48.00</DIV><DIV>Lower Ball Joint $55.00</DIV><DIV>Pitman Arm $83.00</DIV><DIV>Idler Arm $64.00</DIV><DIV> </DIV><DIV>These are all AC Delco Parts</DIV><DIV> </DIV><DIV>Email me at <a href="mailto:kgundrywhite@canadianhummerclub.com" target="_blank">kgundrywhite@canadianhummerclub.com</A> and I hook you up with what you need!</DIV><DIV> </DIV><DIV>Kevin</DIV>
- Injunfarian
- CHC President
Hey Whitehumh2 do you happen to have the AC Delco Part #'s for these items? Thanks!
