Undercoating
3dinnovations
Undercoating
Post by 3dinnovations »
I would like to undercoat my H1 with Ez Liner box coating:
http://www.canadiantire.ca/browse/produ ... 2149890540
What do you guys think? Is this a good or bad idea?
Ride Hard!
Re: Undercoating
[quote name='3Dinnovations' timestamp='1322149974' post='33020']
Hi Scott,
I just had my H2 completely rustproofed and undercoated at VitroPlus. They even put a special undercoating that is designed for use on offroad vehicles. They did my frame inside and out and all suspension components and the entire underside of the body. They did a super great job, and it only cost $150 + tax.
priuseater
Re: Undercoating
Post by priuseater »
Personaly i would choose something else, ie a yearly applied oil based spary for rust protection. However if i were going to undercoat the frame with a undercoating "paint" per say.. I would go with POR-15. Ive used it for alot of ground up golf cart projects, and its awesome stuff <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> "Virtualy" chip resistant, and it actualy absorbs the water away from any rust when you apply it, to help pervent the rust to continue growing. The only thing is that its not UV resistant, so i think you need to coat it with another type of paint if its exposed to the sun.
Just dont get it on your hands and dry or you will have it on there for a good month or 2. Ask how i found out <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />
3dinnovations
Re: Undercoating
[quote name='Polar Bear' timestamp='1322153669' post='33023']
Hi Scott,I just had my H2 completely rustproofed and undercoated at VitroPlus. They even put a special undercoating that is designed for use on offroad vehicles. They did my frame inside and out and all suspension components and the entire underside of the body. They did a super great job, and it only cost $150 + tax.Kev
Thanks Kev! But unfortunately we don't have them were I live. The closest one is an hour away, 1.5 hours in a Hummer!
[quote name='Giverdiesel' timestamp='1322157472' post='33025']
Personaly i would choose something else, ie a yearly applied oil based spary for rust protection. However if i were going to undercoat the frame with a undercoating "paint" per say.. I would go with POR-15. Ive used it for alot of ground up golf cart projects, and its awesome stuff <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> "Virtualy" chip resistant, and it actualy absorbs the water away from any rust when you apply it, to help pervent the rust to continue growing. The only thing is that its not UV resistant, so i think you need to coat it with another type of paint if its exposed to the sun.Just dont get it on your hands and dry or you will have it on there for a good month or 2. Ask how i found out <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />
Thanks! I'll check it out for the POR-15. And I should be good for UV protection cause I usually run my Hummer with the wheels on the ground <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
Ride Hard!
Gadgets
Re: Undercoating
Post by Gadgets »
[quote name='3Dinnovations' timestamp='1322158610' post='33026']
Now I was told, if you are doing that, you're not trying hard enough! <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
Re: Undercoating
<img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' />
duncanpa
Re: Undercoating
Post by duncanpa »
OMG....you guys are so funny......driving with your tires on the ground....had a kid ask me if my Hummer could climb up a building .... told her it probably could if I had a winch....but now I am worried about the UV protection thing as the wheels wouldn't be on the ground... <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
3dinnovations
Re: Undercoating
<img src='http://www.canadianhummerclub.com/forum ... adbang.gif' class='bbc_emoticon' alt=':headbang:' /> <img src='http://www.canadianhummerclub.com/forum ... adbang.gif' class='bbc_emoticon' alt=':headbang:' />
Ride Hard!
Gadgets
Re: Undercoating
Post by Gadgets »
[quote name='3Dinnovations' timestamp='1322227242' post='33050']
Ah he probably just parked it that way, so he could take a leak in the bushes! <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />
Re: Undercoating
omg... at first I thought that was TOM...hahah
