[quote name='Khamul' date='04 October 2010 - 09:33 PM' timestamp='1286249591' post='21642']
Well... we had a blast - but easily some of the toughest trails we have ever done to date!!! Like these were actual quad trails with no doubt about it. We spent about the entire day going along the trails and when we thought we were coming to the end and coming out around the Old Man River exit..... we were brought to a dead halt by a bog. Impassible!!! This was at around 5 and it was already getting dark!
We tried to go around on what we thought was fairly dry ground but Karl basically sunk into it and got thoroughly stuck.... So I tried to come into where we thought it would be safe and hook straps with him, and I got stuck... entire front end ended up digging a hole down to the body. Tried winching out with Chris's winch but not strong enough... after digging out and adding in rocks and wood to climb on... finally got me out. Then attached all the straps together and used Kris's winch to pull Karl out of his hole. But I should say at this point 2 hikers came along and helped push and I think that's what gave the extra little bit we needed.
Sad part is.. about 20 minutes prior to this point we encountered some quads on the trail and they said to basically turn around as they barely got through..... did we listen?
I'll let Karl fill his part in so I won't say anymore about that, but I didn't get home until 4 in the morning...... I was a little tired....
There was no room to maneuver on most of the trails so at one point when I was trying to turn around, I hit a tree and bent my bumper. LOL - so yesterday I rolled her down my driveway to the street off the curb, put by floor jack on the curb for some extra height and jacked it up under the bumber and then bounced on the side steps and i did manage to get it back up to almost what it was before. Made a mess of the passenger side of the Hummer though so I think I will go to that spa place and get a quote for getting my paint repaired.. I'll wait until after the 23rd though... I can't wait until I have the money and I'm getting the Detroit TruTrak upgrade for the front... I also realized the importance of a winch!
Well I personally made it home a few hours before Dave... CUZ HE DROVE ME TO LETHBRIDGE!!! Thanks to you my friend! You are one of a kind. We had to leave my Hummer on the trail though... I went back for it and she's home now, but it was a hell of an adventure!
Short version...
- The trails were awesome! Getting stuck so bad in the peat bog was not.
- Our Hummers were amazing! Except when my lower left differential casing bolt broke and the diff jumped up and sheered off the oil cooling lines housing from the side of the engine block.
- The day was warm and sunny. Except when the sun went down and my Hummer was OIL-LESS in the middle of a skinny muddy trail about 2 hours from gravel road and I was covered from head to toe in mud and engine oil.
- The drive home was... Quiet/subdued/pissed off
- 36 hours later I began a day of toosl and parts gathering.
- 16 hours after that I was camped at top of the trail head at 1 AM with a few great guys in a monster Grand Cherokee, an older Landrover with no tires, and a Quad.
- Next day was spent: Trying to get an air compressor to work (never did); Trying to drill with an electric drill the 6mm Housing bolts so we could reTap the holes (didn't work); Tapping the oil outlet holes themselves to allow screwing in two bolts to block them off and hope some oil pressure would build. We had about 30 minutes of light left after the taps were done.
- Out of 3 vehicles down there we didn't have 2 bolts of the right size to fit in the oil outlet holes...Soooo, I borrowed one from a rear shock and we cut it in half and used those! (It leaked like crazy but worked).
- Replaced the bolt in shock with an oversized bolt and (no kidding) 12 washers!
- Tied down the Diff with a new bolt and plenty of washers and nuts. Now it was getting dark and we had to get heading back up a steep muddy trail.
- 7 Gallons of oil later and a $265 tow I was home with my baby at 2 AM.
- Tomorrow she goes into the shop to get the screws out, the broken bolts out, new bolt holes tapped and the oil cooling lines reattached. I'm sure that won't be a cheap bill.
- I have to order the correct bolt for the diff from GM, but if it ain't at least Grade 8 I'll just get a better one made!
...can't wait until I get out there again!! Anyone else wanna try it?
Karl
PS.. Pics and vids in a day or two.
