OK guys, I have completed the installation of my new Police Scanner. It is a Uniden Bearcat 355c scanner, and it was chosen because of it's small size to fit its intended location.
I do not use my OnStar, and could never see me doing so, so figured I would make use of the space. For the antenna I installed a splitter behind the factory radio. This way the scanner will share the existing factory installed antenna and not require one of its own. You can buy these on the internet for $15-$30 (plus shipping) but I put together my own. I used a High Performance 5-2050Mhz splitter ($2.99 Princess auto) and standard cable F-connectors I figure the splitter cost me no more then $6. It works great, there is no sign what so ever of signal loss on either the Scanner or Radio. The pictures before, during, and after, show the proceedure.
Un-boxing of Scanner ^
Dash before starting ^
Dash without covering ^
Radio Removal, for antenna splitter installation ^
Antenna splitter installed ^
OnStar Module removed ^
Open space for Scanner ^ (there is NOT a lot of depth here)
Test fit the scanner ^
Testing the power and antenna connections ^
Test fit with all electrical (power, antenna, and external speaker) connectors on the back ^
The heavily modified OnStar faceplate ^
Scanner bracket mounted ^
Scanner mounted in bracket ^
Modified OnStar faceplate installed ^
Completed installation ^
Install Scanner in OnStar Location
- Gadgets
<p class="bbc_center">
- thedub
Re: Install Scanner in OnStar Location
That looks great Gadgets <img src='http://www.canadianhummerclub.com/forum ... SMILEY.gif' class='bbc_emoticon' alt=':woot:' /> nice job and now I know what I want to put in my onstat slot <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
[center]Yellow H2
Mississauga, Ontario.
- Hesh
What did the bearcat run you? Ive got one from the previous owner in my truck, but I never had it dialed in/programmed for the local LEO's around here, I should get on that...
- Gadgets
[quote name='Hesh' timestamp='1326691019' post='34473']
It was around $120 CDN after shipping. I bought two at the time, one for my H2 and one for my son's Ranger. Works great. One of the smallest on the market I think.
that looks great... I like that!!<img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
- Gadgets
[quote name='dwaxman1' timestamp='1327182306' post='34573']
Thanks Derek, the antenna sharing is working great, today I was in Burlington and was still clearly listening to the st.catharines fire command, and a truck at a scene. So reception is awesome!!
- Boeing Jet
Thanks a lot Gadget. Now I have to install another toy in the truck. One place I look first for toys like this is at Radio World Radio here in Toronto
http://radioworld.ca/mobliebase-scanner ... lter_id=13
- Gadgets
[quote name='Boeing Jet' timestamp='1327269082' post='34594']
Yup, have gotten stuff there as well, actually I think my K40 CB antenna came from there. This scanner came from Durham Radio in Whitby this time though.
where did you install the external speaker? and when are you going to do my install??
- HummerBee
Nice job That looks slick!
