Hutchison Beadlock Wheels
So a Buddy of mine had me assemble a set of 17x8 Hutchinson Dual Beadlock wheels for his Jeep. These would also be great for any H2 or H3 with the proper bolt pattern. Never try and install an H1 two piece Wheel on an H2...bolts will contact brakes!!!!
This is what comes in the box;
Re: Hutchison Beadlock Wheels
Here are all the pieces as I get ready to assemble them;
Step one; Install the rubber beadlock into the tire...surprisingly easy to do btw!
Note; I choose to align the air channel groove with the RMA Symbol on the tire just to have a reference and to keep them all the same!
Next install the super size o-ring on the upper rim half and apply a very generous amount of lubricant to the beadlock and tire beads to ensure a smooth and easy seating of the bead to the rim flange.
Now use the three long studs and hand tighten the rim halves together to eliminate any chance of vibration causing the seal to come out of position and to ensure you have an even and well seated bead.
Now install the remaining self lock nuts and be sure to keep the upper and lower portions aligned. Torque each Wheel in a triangle pattern with a 100lbs-ft torque. Do 5 complete passes in order to ensure that the bolts are truly equal and snug. Then air them up!
And finally here is the finished product;
Before;
After;
They even look good on a Jeep!
So who wants a set for their Hummer? ????
Skenth
Post by Skenth »
What's the $ and size of the rim...16.5?
Sonny Kenth
nitrous
Post by nitrous »
Rim and tire package must be about the same value as the jeep. I would really like a set for my H1
Looks nice
17x8
They were about $400 a Wheel without tires!!!
GreenMeanie
Post by GreenMeanie »
Decent price. What is the load rating on each rim?
