High Powered LED Projection headlights
Chrome and flash more your style? You rolling on 24”s or larger? You shine you ride regularly? Then this is the place!
chrisbernard
Post by chrisbernard »
I do custom installs.
If you are looking for high powered LED projection headlights or driving lights, please contact me.   thinair@shaw.ca
Re: High Powered LED Projection headlights
Would you be able to post some comparison photos of the Stock vs the LEDs vs some HIDs?
That would be very helpful!
Thanks,
Big_Dub
Post by Big_Dub »
Good First post....An Ad for your business..........
Rhino now has h13 led bulbs in. They cost about the same as the lumens hid's and give similar light without all the additional wiring.
 LED The normal lighting harness plugs directly into small "ballast" boxes less than 1/4 the ballasts of hid's, 2 plugs go to the each of the bulbs and fan units that screw on to the bulbs which fit in as normal bulbs and done. (FreeThrottle system)
Hids use a switcher box which takes power from battery (additional fuse) and 1 stock lamp plug. (2nd stock plug on passenger side has to be sealed off) a cable then runs across front to ballast on passenger side and both balasts attach with two plugs to lamps. and also 1 or 2 grounds must be established for cabling wires. Note on Rhino the hid's failed to light at times like when starting or steping down to daylight or drivers side we tried 5 sets of bulbs and two compleat sets of hid kits both had same problem additionally the bulbs were incompatable between the kits  WE DO NOT RECOMEND HID SYSTEMS for these reasons .
Big_Dub
Post by Big_Dub »
For anyone interested in the OP's content here is a link for similar look lamps.
<a href="http://www.ebay.com/itm/JW-Speaker-8700 ... wt_1273</a>
Sugarphreak
Post by Sugarphreak »
[quote="Big_Dub"]
:coffeespit:
To be fair, I did a quick facebook stalk on the user name. He isn't in the headlamp installation business, he is a photog.
If I had to guess he owns the H2 and he wants to sell these.
<a href="https://www.facebook.com/photo.php?fbid ... 4335755</a>
EDIT: Never mind, according to his post he is installing them for a  customer
Big_Dub
Post by Big_Dub »
Good To Know that if he wasn't a photographer he would have a custom fab shop......because installing direct bolt in replacment LED lamps is custom Fab :rotflmao:
Rhino is now fully Led lit at front end save the H3 bulbs in ARB foglights and the foreward facing OEM turn/clearance lights sides are set of bulbs from A1 components and are brighter than the originals.
