"Service 4WD" message on DIC for 2003 H2
collega
Post by collega »
Hi. About one month ago I got message on my DIC"Service 4WD" on my 2003 Hummer H2. I didn,t do any offroading or severe driving conditions. After stopping car message didn't come back. After one week of driving-appeared again. Right now it's coming out very often. Do anybody have any idea what to do? I know I should go to pull out code number from dealer,but I don't want to do it. Any other idea.
Thank You.
Hummer,like nothing else!
Re: "Service 4WD" message on DIC for 2003 H2
steve??
[quote name='dwaxman1' date='18 February 2010 - 11:00 PM' timestamp='1266552028' post='1698']
steve??
Quick list
speed sensor or wiring to said (happened on 2001 Jimmy)
encoder malfunction (H3 alpha finally failed completely)
kevin
Post by kevin »
Mine did that twice while pulling my trailer last summer and hasen't been on since
2007 H2 Black
I have never seen that on my Truck, well at least not yet...I do keep it serviced a bit more then the average guy.. I change my diff fluids probably more regularly then required and also the whole off road thing puts my truck at a bit more strain and therefore I get it checked over often and greased well...
anyways I suggest you buy a quick code reader, I got my at crappy tire for about $150.. well worth it compared to what a dealer may charge you to just read a code..
olishooter
Post by olishooter »
Yes the repair needed is a software upgrade to eliminate the unwanted service 4wd light. It doesnt always represent a problem so a code reader may not be your answer also an H2 is totally different than any H3 alpha or not, the H2 only has some related components to gm full size pick-ups. I can assist you in the repair if needed or you will have to go to your local dealer for this software upgrade. Now I am only comparing your hummer to past experiences but an inspection of the 4wd system is needed to proper diagnosis this problem. Any other questions or concerns i would be happy to help. cheers
hummerht2
Post by hummerht2 »
on my 2005 the same thing and Kevin just change tfe transfer case fluid
collega
Post by collega »
[quote name='hummerht2' date='19 February 2010 - 05:22 PM' timestamp='1266618175' post='1719']
Thank You for your answer. Did it help? That message "Service 4WD"'ve gone after changing transfer case oil or not? Actually I have around 106000km mileage and I don't know did previous owner change it or not in generally(I bought my track around 1 year ago).So it's good idea.
collega
Post by collega »
[quote name='olishooter' date='19 February 2010 - 12:54 PM' timestamp='1266602077' post='1714']
Thank You very much for answer.How much will it cost to inspect my truck and to find out problem. If You can give me your contact phone number I can call You and maybe come to You to ispect it(I am living in the north of Richmond Hill).
collega
Post by collega »
[quote name='dwaxman1' date='19 February 2010 - 11:11 AM' timestamp='1266595892' post='1709']
Thank You for your answer. Can You suggest that I should change oil in my transfer case to eliminate this problem?
