No Air Suspension!
collega
Re: No Air Suspension!
Post by collega »
[quote name='Samson' date='16 April 2010 - 08:42 PM' timestamp='1271468553' post='15764']
hey,just looking for a little advice on my air suspension. I was hoping there was a common problem and an easy fix for it. I don't want to go to a dealer if i don't have to!!
If You are from Toronto area ask Steven Olivera for advice. He is experienced mechanic who did a lot of work with GM trucks and paticulary with Hummers. His pnone number is:(905)455-8888. You can see his add at sponsors area "Master Mechanic". Try to ask him. You can ask him as "Olishooter"-member of our Canadian Hummer Club too.
Hummer,like nothing else!
duncanpa
Post by duncanpa »
I can tell you right now that Steve will probably recommend that you take out the air suspension. He has worked on my Hummer and he has told me already that if it goes, rip it out. The replacement parts are pretty close to $3,000 and labour...well...that would make it just crazy. I have seen some replacement air suspensions on ebay for about $1,500. I guess it all depends on what the problem is and what components are involved. Email Steve, he will get back to you quite quickly. Be sure to tell him all that is wrong with it so you get good advice.
Get a hold of Kev whitehum2 , he just redid the entire system I believe. Would be a good person to ask anyway!!
Hey Kev, you need a set of rim protectors???
rim protectors FOR H2 WOW PICS PLEASE
[quote name='T.C.' date='17 April 2010 - 11:32 PM' timestamp='1271561572' post='15792']
got 1 more revision first, then the H3 ones
[quote name='Roy' date='18 April 2010 - 03:03 PM' timestamp='1271620990' post='15815']
cool <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
