Tire Pressure
1650shawn
Tire Pressure
Post by 1650shawn »
Hi guys,I would like to know how low I can drop my tire pressure without any risk of them popping off the rims.I don't have beadlocks. <img src='http://www.canadianhummerclub.com/forum ... ey-013.gif' class='bbc_emoticon' alt=':wtf:' />
[center]*[/center]
Re: Tire Pressure
[quote name='1650shawn' date='19 April 2010 - 03:53 PM' timestamp='1271710414' post='15851']
20 TO 25 PSI SHOULD BE FINE (COLD NOT HOT)
1650shawn
Re: Tire Pressure
Post by 1650shawn »
Thanks <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> TC
[center]*[/center]
Re: Tire Pressure
[quote name='1650shawn' date='19 April 2010 - 05:39 PM' timestamp='1271716753' post='15864']
no problemoooooooooooooooo <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Re: Tire Pressure
I my self have run with 16-18# with no trouble.Like to be a little safer and keep at 20# pressure . Depends on which tire you have as to how far down you go. MT 's need to go at least to 20 to get side wall flex. Toyo's at 22-24 ish
Also depends on the area being traveled. Sand 16, rocks 20, mud 22-30.Lots of factor to take into consideration. <img src='http://www.canadianhummerclub.com/forum ... ngHead.gif' class='bbc_emoticon' alt=':banghead:' /> <img src='http://www.canadianhummerclub.com/forum ... ngHead.gif' class='bbc_emoticon' alt=':banghead:' />
Re: Tire Pressure
[quote name='Roy' date='19 April 2010 - 07:22 PM' timestamp='1271722976' post='15872']
duncanpa
Re: Tire Pressure
Post by duncanpa »
Hey Everyone....come out to the Hummer Rally to learn more from these experienced Hummer Drivers!! Learn what your Hummer can (and cannot) do and push the envelope on your FEAR FACTOR!!! It will be an absolute GREAT time. Hummer Rally....BE THERE!! <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Re: Tire Pressure
[quote name='1650shawn' date='19 April 2010 - 09:53 PM' timestamp='1271710414' post='15851']
Actually My Portly H2 has popped a bead twice while off-roading with the tires at 25psi!!! That is why I am installing the Staun Beadlocks...No MORE PROBLEMS!!!
Re: Tire Pressure
[quote name='duncanpa' date='21 April 2010 - 03:28 AM' timestamp='1271816935' post='15933']
I Don't Understand?<img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' /> <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' />
There is something that My Hummer Can't Do??? <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' />
Oh wait you are talking about your Hummer...I get it!! <img src='http://www.canadianhummerclub.com/forum ... lleyes.gif' class='bbc_emoticon' alt=':rolleyes:' />
Re: Tire Pressure
[quote name='Polar Bear' date='21 April 2010 - 07:54 AM' timestamp='1271854467' post='15952']
<img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
