Front End Issues With An H1
Re: Front End Issues With An H1
[quote name='gstacky' date='27 May 2010 - 03:34 PM' timestamp='1274992493' post='17418']
Hey guys, we have an H1 in the family, and it's giving us a little trouble. Runs great, but when driving and we hit a bump, the front end starts into a wobble and you almost have to come to a stop to get it to quit. It will rip the steering wheel out of your hand if you're not careful. Any idea what to look for? It doesn't have a lot of miles on it, and doesn't see any kind of weather or off road situations. Any help is greatly appreciated.
Greg
p.m. kevin aka Polar Bear ....i am sure you will get the info you need
1650shawn
Post by 1650shawn »
[quote name='gstacky' date='27 May 2010 - 04:34 PM' timestamp='1274992493' post='17418']
Greg
Hey gstacky,I would check out your shock absorbers.If 1 or both have lost their air or oil that could cause your wheel(s) to shake out of control.
[center]*[/center]
IF YOU NEED SHOCKS FOR YOUR H1 ASK ROY...I AM SURE HE CARRYS EXTRA STOCK....GOOD LUCK KEEP US POSTED <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
[quote name='gstacky' date='27 May 2010 - 09:34 PM' timestamp='1274992493' post='17418']
Greg
You need some serious steering work, your steering box will definitely need an adjustment but it could also need to be replaced. You probably need a pitman and an idler arm and even some tie rods. But the most likely cause of 'The Death Wobble' is a seriously out of adjustment steering box!!!
[quote name='gstacky' date='28 May 2010 - 07:19 AM' timestamp='1275049185' post='17462']
Thanks guys, I'll check that out and see what I can find.
Great site by the way:)
IF YOU NEED PARTS ASK ,THERE ARE LOT'S OF GUYS ON THIS SITE THAT CAN HELP...GOOD LUCK...HUMMER BROTHERRRRRRRRRRRRRRRRRRR <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
NorthBayH1
Post by NorthBayH1 »
for me it was 2 tie rods and a pitman
what caused yours Austin??
NorthBayH1
[quote name='dwaxman1' date='15 June 2010 - 06:37 PM' timestamp='1276623472' post='18249']
for me it was 2 tie rods and a pitman = death wobble
