Whining
- 1650shawn
Whining
I've been hearing a little whining coming from underneath these past few days.Only does it whe the engine is warm.Stops when idling.So,I'm quite sure its something that rotates when the vehicule is moving. I topped of the transmission fluid and it still whines.If the hubs are missing fluid,do they whine? I'm pretty sure it's not the brakes.They would make a scraping sound.This is much more of a whine.
[center]*[/center]
Re: Whining
SEND A PM TO KEVIN <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> KEEP US POSTED
- 1650shawn
Re: Whining
I think it may be the center link bearing.Will have it checked on Wednesday.
[center]*[/center]
- 1650shawn
Re: Whining
The whining is coming from the the main drive shaft support bearing. Garage can't get the part from any local parts store.Anyone know where I can order it from? It was a bit loose when I bought the truck this spring. Must have been the mud from Weir that got in it. <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt='
' /> So,I have a choice to make after replacing the bearing MUD OR BEARING,MUD OR BEARING, MUD OR BEARING <img src='http://www.canadianhummerclub.com/forum ... ey-013.gif' class='bbc_emoticon' alt=':wtf:' /> MUD MUD MUD of course
Here is a good article on the subject
http://flashoffroad.com/Maintenance/Dri ... eShaft.htm
[center]*[/center]
Re: Whining
[quote name='1650shawn' date='30 June 2010 - 01:44 PM' timestamp='1277919899' post='18711']
I have one still in the box, too lazy to replace it.
SKF-HB88107-b
The number that is called for is a 211415x or 5741082 -AMG, same specs as the one I have listed above. 35mm bore , 1/2 bolt holes,6.62 centres and 2.25 from mount to bearing centre.The mount width is a bit wider but it does not matter.
SKF-HB88107-b
- Boeing Jet
Re: Whining
Its the hanging bearing you're looking for right? If so, there is a place on Dixie by the Airport. I'll get the name on Monday.
Re: Whining
[quote name='1650shawn' date='30 June 2010 - 12:44 PM' timestamp='1277919899' post='18711']
<img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> MUD IT GETS TO US SOONER OR LATER TRUST ME I KNOW <img src='http://www.canadianhummerclub.com/forum ... lleyes.gif' class='bbc_emoticon' alt=':rolleyes:' />
- 1650shawn
Re: Whining
[quote name='Roy' date='02 July 2010 - 07:51 PM' timestamp='1278114714' post='18784']
SKF-HB88107-b
Thanks Roy,thats the part number(211415x) he used,but he wasn't sure.I will pick it up and have it changed this week.
SKF-HB88107-b
[center]*[/center]
