Crazy Canucks 4x4: quick question. With the geared hub came a black rubber like seal. It was not in the manual or anywhere on the old unit. I recall you placing it on the geared hub.
Is it an important piece? The entire unit is together and working but if its going to be a problem then ill rip it apart tomorrow and install. I did not see it on the old geared hub. I'll try and take a picture of it and post if that will help.
H1: Wheel Falls Off?!
Re: H1: Wheel Falls Off?!
[quote name='slowbutsteady' timestamp='1356677020' post='41548']
That piece goes on the CV shaft as an extra dirt seal. Seal are now a 2 pc design.
Glad to hear it is back running. Any question in the future, just phone.
