Upgrade tires and torsion bar lift
Re: Upgrade tires and torsion bar lift
with lt 285 tires you will find that their the alternate size for the H3's . We went with american eagle serries 064 rims they look nice and have about 1 1/2" less backspace ( like having a 1 1/2" spacer plate)
gram
Post by gram »
The problem with wheel spaces is they fix the tire rubbing the swaybar at full turn, but now the back side of your tire will contact the body when turning the other way full turn. On the street might not be an issue but offroad driving over something might jam your wheel when using a full turn. All i did on my truck is level it and install 315/75R16. Look at my pics if you wanna see the results. You will have to replace the front shocks, to illiminate the bounce
