Annoying Sound
BrunoGerardo
Annoying Sound
Post by BrunoGerardo »
thejudge
Re: Annoying Sound
Post by thejudge »
Just a couple guesses. First check your tires for any stones or screws that might be stuck in there. My other guess, when was the last time you changed your brake pads? my old truck made a similar noise and it was from a piece of the brake pad had broken off and was rubbing a little bit.
BrunoGerardo
Re: Annoying Sound
Thank you. It at 60,000 miles maybe once
gram
Re: Annoying Sound
Post by gram »
Sounds like a brake pad wear indicator when it is on the wrong side of the caliaper. Other than that or brake pads falling apart those bendix style front brakes are bullet proof. Check that front wheel bearing for play while your there too.
Stevegt
Re: Annoying Sound
Post by Stevegt »
I once had a noise like that it ended up being the back of my rims was corroding and the chrome was peeling off and hitting something
