Recently noticed an unusual amount of loss control when I go over significant bumps or pot holes. It starts to feel a bit tippy and I notice a lot of movement that wasn't always there. Thinking it might be a loose steering mechanism or linkage, failing ball joint, tie rod end or a control arm issue.
Has anyone had a similar issue?
Thanks
Failing front suspension component 07 H3
- erynkaye
- shotgun-cam
Re: Failing front suspension component 07 H3
Ok on a recent inspection our 08 H3 alpha was found to have a bushing that is loose. The only real way to find your problem is an inspection (Rhino's was found during a brake job and no real effect on steering). But to add to your list add shocks or springs.
- gram
The thimg that has the most noticable affect on steering on an h3 is the hub assemblies, (front wheelbearings). If you are running a larger offroad tire you wont hear it starting to go untill it has developed severe play.
