H2 Mirrors not folding in
Gadgets
Post by Gadgets »
Hi guys, both my outside mirrors have stopped folding in when I hit the button. They both stopped doing this at the same time. I can still control the mirror angles themselves but the whole housings no longer fold in.
 I looked in the manual for a fuse for them but didn't find anything, does anyone know what fuse this could be or any other thoughts?
  Thanks,
        Brian
<p class="bbc_center">
duncanpa
Re: H2 Mirrors not folding in
Post by duncanpa »
Mine did the same thing and I was told that god actuators are gone. Since it is one self-contained unit you would gave to buy new mirrors. I am okay with them notbfolding in right now.....
Gadgets
Post by Gadgets »
You think they both would have went at the same time? They were working fine then both stopped.
normsadler
Post by normsadler »
I think you'd have to take the door apart and check voltage at the connection to the mirror.  It may just be a corroded connector or bad switch.
Norm & Sue
2010 White H3T (sold)
Gadgets
Post by Gadgets »
I'm starting to think bad switch or like you say corroded wire. I have discovered that if I manually push both mirrors in, I can fold them back out again with the button, it's only folding them IN that is a problem.
