Sluggish Acceleration Hummer H1 6.5 non turbo Diesel
- Skenth
Re: Sluggish Acceleration Hummer H1 6.5 non turbo Diesel
Found the drain and fuel does come out on idle
Sonny Kenth
- Boeing Jet
Well that's a good start. That drain empties the bowl where the fuel filter is.
- Skenth
Thanks Boeing Jet.
I'll give you a call and try to change the filter and pump. I've read up on it and ordered the parts. Ill call u when my parts come in.
This forum is a great help. Thanks everyone. Looking forward to getting my hands dirty with grease (as opposed to saliva and blood...i'm a dentist!)
Sonny Kenth
Its an easy job, and after done, you'll sit back and be proud
Hopefully goes smooth for ya
- Boeing Jet
No problem Sonny. Let me know and I'll swing by.
- Skenth
Local parts store has the pump on backorder...hopefully next week. I'll see if Roy has it and can ship it
Sonny Kenth
- Boeing Jet
Ok. I have a spare fuel filter if needed.
Pump installed, relay not working all the time, by-passed, test drive, no throttle response. Next item will be the TPS.
If anyone has the specs for the tps replacement and set up, please forward to me please. 96 non turbo 6.5
- Skenth
Here's what I found regarding TPS on 4L80E 1996 hummer H1 NE.
I got my friend to change it with those specs but still no power on acceleration. What's the next trial and error (PCM??)
Sonny Kenth
- Skenth
Hmm..Roy, should we look into "pressure switch problem in the valve body most likely due to an electrical fault or perhaps the pressure switch froze up". Is that something I could get done at your place. I'm almost done arranging the tow details.
Will be in touch
Will be in touch
Sonny Kenth
