Hi, I am looking for a drivers door hinge pin / bushing kit for my 2005 H2. i cant find anything listed from Dorman, autosource etc. does anyone know a supplier or are the pins / bushings the same as a 05 GMC Sierra ?
Thanks for any help
H2 Door Hinge Pin Kit
Re: H2 Door Hinge Pin Kit
Ok there is a super simple solution!
Order one set of Dorman 38437 door pins per door that needs to be repaired and you will be good to go!
These are the same parts used for all Chevy Truck doors from 1998 up
I just needed to take some measurements to be certain
Hope this helps!
Hope this helps!
- DuhBigDog
Thank you very much for the help, i will do just that. its just the drivers door that is dropping when opened.
- Stevegt
Just got quoted $1000 dollars to fix this, does anybody know if this will also work on a 2004 H2
This repair will work on every H2 from 2003 to 2009!
This is under a $50 repair per door!
Hope this helps!
Hope this helps!
- Stevegt
Thank you, this really helped a lot, do you know where I can buy them from?
Any Auto parts store!
