body mount size for the turbo guys?
Ok I have the N/A 96,
This year offered,
6.5 N/A,6.5 turbo ,5.7 gasser, can you tell with this pic if this mount is same as all turbo's? Or is this being n/a motor ,is my truck lower a little?
Re: body mount size for the turbo guys?
Not sure why photo went sideways as was straight on phone
Only difference is that the turbo model has a 1/2 steel spacer to raise body up more.
