Tube with wires under rear fuel tank
Rocrusher
Post by Rocrusher »
Anyone know what these are for? It's a plastic tube running from passenger side to drivers then to up front. I followed them to just under the rear seat and they are cut and go to nothing. Was thinking of removing it all.
Re: Tube with wires under rear fuel tank
Hmmm, only thing I had that was tubes were the lighting wires, for reverse/running/blinkers....
I'm wondering if that's it, was any corrosion ?
But I'm sure other would know more,... Only reason I think this is lol I keep losing rear running lights due to chaffing broken wires
Rocrusher
Post by Rocrusher »
Nope not that. This tube end and has a rubber cap on the end on the passenger side. Its like its there for an add on or something. I will take a pic of it tomorrow.
Ya curious as well ....
also trailer harness?
Rocrusher
Post by Rocrusher »
So I am thinking this may have been added on by previous owner but may one of you may know
ddgermann
Post by ddgermann »
I dont have one of those... Tore the truck to little pieces a couple years ago and didn't see that.
Must be an add on.
DG
Rocrusher
Post by Rocrusher »
Thanks i think your right. The straps that hold it up are those cheap plastic ones. Will dive into that later as i still have that stupid thumping noise on acceleration and have the rear brakes calipers half shalfts and stuff all apart trying to figure it out.
ddgermann
Post by ddgermann »
Body mounts on the thumping? I got rid of my thumping by tightening them up. LH front was the worst. Of course it is famous for coming loose too. The rest in the back....yup been there. It feels good when you get it done. Sucks doing it.
Cheers,
Derek
Rocrusher
Post by Rocrusher »
Body mounts are good. Thumping is while on throttle or heavy braking. Found a bad inner cv. But i don't think thats it. Would think that should be a growling or constant noise. But we will see. I am also putting on front calipers on the rear to eliminate park brake sticking until i rebuild them.
Why put fronts on, I carry rebuilt calipers..exchange...
