SERV TPM
- ddgermann
Re: SERV TPM
Unless you added it.... correct no onboard air compressor on your H3.
You tires likely just need a top up from the cold air. This warning should disappear when your tires warm up driving but if it’s coming on at all you likely need more air. I never had this issue with our H3 running 33” BFG TAs
Possibly your TPS sensors are running out of battery and need replacement.
Either way not a big issue.
Good luck and let us know how it works out.
- thejudge
Re: SERV TPM
This message pops up for me too for a second when it’s really cold.
Might need to replace your tire pressure sensors, mine are long over due.
- MRVAPER1
Re: SERV TPM
topped up the air msg went away. amazing how much pressure tires lose in the cold
- collega
Re: SERV TPM
I had such message couple times on my H3 during the coldest winter mornings. After short drive it will be disappeared.
Hummer,like nothing else!
