Oversized tires
- Sugarphreak
Re: Oversized tires
Checked out the vids, pretty interesting!
That sounds pretty similar to my current plans, just a leveling kit, bumper & a set of new tires. I still want to maintain the factory warrenty as long as possible so big lifts & other large scale changes will have to wait for a few years.
On a side note you guys really have to stop calling me "sugar" <img src='http://www.canadianhummerclub.com/forum ... iggrin.gif' class='bbc_emoticon' alt=':D' />
- Sugarphreak
Re: Oversized tires
Quick question; Does anybody know if am I going to have an issue with the wheel width for the Toyo 35" tires?
The reccomended wheel widths range from 8" and up.... the stock wheels are only 7.5" wide.
- Sugarphreak
Re: Oversized tires
I just got the torsion keys in.... these things are HUGE!! I put them on the scale and they weigh in at 6.2lbs each, they look and feel like forged metal.
Hmmmm, Torsion Puller Tool?
Cell Phone Pic
[img width=500 height=428]http://i211.photobucket.com/albums/bb25 ... antbar.jpg[/img]
Cell Phone Pic
- Khamul
Re: Oversized tires
For the wheel widths you should have no issues at all...
The toyos's are exactly the same in size at the Procomps and they fit like a glove!
- Sugarphreak
Re: Oversized tires
The guy who is going to put my tires on said that it isn't really a big deal to squeeze them onto 7.5" rims, in fact a lot of off-road guys like to run narrow rims. The only thing he said I would encounter is a bit of uneven wear, likely more in the center of the wheel and if I were to run a wider rim.
I am going down to pick up the tires on on Wednesday, hopefully I can install these keys tomorrow after work. If the install goes smoothly today I will book some time either this week or next to have the tires put on.
- Khamul
Re: Oversized tires
So when are us Alberta boys (and girls) going to do another ride???
Where is everyone?
Where is everyone?
- largemouthbass
Re: Oversized tires
Guys,
I will speak from direct experience here and will only discuss the H3/H3t.
The leveling kits (torsion bar re-indexing keys) are a complete waist of money. I still can't believe people are buying those things for our trucks.
There is lots of room for adjustment of the t bars on our trucks and still keeping within proper angles of the front end parts. This has been discussed many many times and there is a ton of good info on this subject on the world wide web.
If you turn your t bars up the rule of thumb is to go no higher than 24" from center of wheel to bottom of fender. Then I suggest you get some longer shocks ie. bilstein cognitos if you do any off-roading and I will suggest longer bump stops unless you like the nose dive while breaking. You can get these as a kit from Trail duty.
http://www.trailduty.com/product_info.p ... cts_id=765
Last edited by largemouthbass on Fri Nov 27, 2009 5:07 pm, edited 1 time in total.
- largemouthbass
Re: Oversized tires
As far as tire size goes, 315's are fine on the I5. With the auto you might notice a slight power decrease and with the manual transmission its next to nothing. I have never heard of touching your battery cables together for your pcm to learn the new tire size?? In some cases your dealer can reprogram your pcm for the tire size change
I will suggest if you do want some power back to get your pcm re-programmed as suggest earlier in the thread.
One more thing, turning up your torsion bars does not make the suspension stiffer. If you read from the link in my previous post you will learn how it works.
Last edited by largemouthbass on Fri Nov 27, 2009 4:40 pm, edited 1 time in total.
- Sugarphreak
Re: Oversized tires
I can verify that, the new tires size it doesn't really have any affect on my H3T other than I noticed my Speedometer was off by about 5%.
It does however rub when you crank the wheel all the way over.
As far as the torsion keys go, yeah after I installed them it was pretty obvious that the amount of adjustment needed could have been achieved on the stock keys just as easily... I kind of wish I had caught up on those other sites before I purchased them now.
I keep hearing people talking about changing to new shocks, for adventure packages that already feature the Blisten shocks is that still true? I had a close look at shock operation and the mechanics of how the key changed the arrangement, it doesn't really seem like longer shocks are really nessisary for such a small height adjustment. Same goes for the bump stops, I didn't experence any nose diving when braking hard or extra roll on corners at all.
- Sugarphreak
Re: Oversized tires
(double post)
