<b>2010 Hummer H3T Sport Utility Pickup 5 ft Truck Crew Cab</b>
<b>$32,000</b>
<b>70,000km Still under warranty!</b>
<b>If you want to own a rare unique truck, this is it! Less than 3000 H3-Ts were built. This was the last year Hummers where made. It is already one of a kind, make it yours.</b>
<b>Options</b>
<ul class="bbc">[*]
AM/FM Stereo
Air Conditioning
Alloy Wheels
Anti-Lock Brakes (ABS)
Bed Liner
Bluetooth
CD Player
Cruise Control
Daytime Running Lights
Dual Airbag
Heated Seats
Hill Ascent Control
Keyless Entry
Leather Interior
OnStar
Panoramic Sunroof
Power Door Locks
Power Seat
Power Steering
Power Windows
Privacy Glass
Roof Rack
Running Boards
Satellite Radio
Stability Control
Tilt Wheel
Tow Package
Traction Control
[/list]<b>Features</b>
ENTERTAINMENT FEATURES
<p style="margin-left:1.27cm;">CD player
<p style="margin-left:1.27cm;">Wireless phone connectivity
<p style="margin-left:1.27cm;">AM/FM radio
SEATS AND TRIM
<p style="margin-left:1.27cm;">Power driver seat
<p style="margin-left:1.27cm;">Front seats: bucket
<p style="margin-left:1.27cm;">Front center armrest
<p style="margin-left:1.27cm;">Split folding rear seat
<p style="margin-left:1.27cm;">Rear seats: bench
<p style="margin-left:1.27cm;">Max seating capacity: 5
CONVENIENCE FEATURES
<p style="margin-left:1.27cm;">Power windows
<p style="margin-left:1.27cm;">Auto-dimming rearview mirror
<p style="margin-left:1.27cm;">Remote keyless entry
<p style="margin-left:1.27cm;">Rear beverage holders
<p style="margin-left:1.27cm;">Passenger vanity mirror
<p style="margin-left:1.27cm;">1-touch down windows
<p style="margin-left:1.27cm;">1-touch open/close sunroof
<p style="margin-left:1.27cm;">Front beverage holders
<p style="margin-left:1.27cm;">Emergency communication system (on-star)
<p style="margin-left:1.27cm;">Illuminated entry
<p style="margin-left:1.27cm;">Speed control
<p style="margin-left:1.27cm;">Air conditioning
<p style="margin-left:1.27cm;">Tilt steering wheel
<p style="margin-left:1.27cm;">Driver/Passenger door bin
<p style="margin-left:1.27cm;">Rear door bins
BODY EXTERIOR
<p style="margin-left:1.27cm;">Bedliner
<p style="margin-left:1.27cm;">Roll-N-Lock tonneau cover
<p style="margin-left:1.27cm;">Power door mirrors
<p style="margin-left:1.27cm;">Rear step bumper
<p style="margin-left:1.27cm;">Trailer hitch receiver
<p style="margin-left:1.27cm;">Skid plates
LIGHTING, VISIBILITY AND INSTRUMENTATION
<p style="margin-left:1.27cm;">Front reading lights
<p style="margin-left:1.27cm;">Low tire pressure warning
<p style="margin-left:1.27cm;">Front fog lights
<p style="margin-left:1.27cm;">Variably intermittent wipers
<p style="margin-left:1.27cm;">Outside temperature display
<p style="margin-left:1.27cm;">Compass
<p style="margin-left:1.27cm;">Fully automatic headlights
<p style="margin-left:1.27cm;">Tachometer
<p style="margin-left:1.27cm;">Rear backup camera integrated in review mirror
<p style="margin-left:1.27cm;">Rear window defroster
SAFETY AND SECURITY
<p style="margin-left:1.27cm;">Overhead airbag
<p style="margin-left:1.27cm;">Ignition disable
<p style="margin-left:1.27cm;">Electronic stability
<p style="margin-left:1.27cm;">Dual front impact airbags
<p style="margin-left:1.27cm;">ABS brakes
<p style="margin-left:1.27cm;">Panic alarm
<p style="margin-left:1.27cm;">Occupant sensing airbag
<p style="margin-left:1.27cm;">Security system
<p style="margin-left:1.27cm;">4 wheel disc brakes
<p style="margin-left:1.27cm;">Traction control
<b>Tech Specs</b>
POWERTRAIN
<p style="margin-left:1.27cm;">Sequential multi-point fuel injection
<p style="margin-left:1.27cm;">Torque: 241 lb.-ft. @ 4,600RPM
<p style="margin-left:1.27cm;">Engine litres: 3.7
<p style="margin-left:1.27cm;">Number of valves: 20
<p style="margin-left:1.27cm;">Recommended fuel: regular unleaded
<p style="margin-left:1.27cm;">Horsepower: 239hp @ 5,800RPM
<p style="margin-left:1.27cm;">Fuel tank capacity: 102.2L
<p style="margin-left:1.27cm;">Engine location: front
<p style="margin-left:1.27cm;">Drive type: four-wheel
<p style="margin-left:1.27cm;">Cylinder configuration: I-5
<p style="margin-left:1.27cm;">Variable valve control
SUSPENSION/HANDLING
<p style="margin-left:1.27cm;">Rear anti-roll bar
<p style="margin-left:1.27cm;">Power steering
<p style="margin-left:1.27cm;">Front anti-roll bar
<p style="margin-left:1.27cm;">Front wheel independent suspension
<p style="margin-left:1.27cm;">Wheel size: 16"
<p style="margin-left:1.27cm;">Tires: all-terrain
SPECS AND DIMENSIONS
<p style="margin-left:1.27cm;">Exterior body width: 1,905mm (75.0")
<p style="margin-left:1.27cm;">Exterior length: 5,403mm (212.7")
<p style="margin-left:1.27cm;">Payload: 494kg (1,090lbs)
<p style="margin-left:1.27cm;">GVWR: 2,722kg (6,001lbs)
<p style="margin-left:1.27cm;">Rear hiproom: 1,336mm (52.6")
<p style="margin-left:1.27cm;">Compression ratio: 10.00 to 1
<p style="margin-left:1.27cm;">Engine horsepower: 239hp @ 5,800RPM
<p style="margin-left:1.27cm;">Rear legroom: 869mm (34.2")
<p style="margin-left:1.27cm;">Engine displacement: 3.7 L
<p style="margin-left:1.27cm;">Rear headroom: 1,003mm (39.5")
<p style="margin-left:1.27cm;">Engine torque: 241 lb.-ft. @ 4,600RPM
<p style="margin-left:1.27cm;">Exterior height: 1,831mm (72.1")
<p style="margin-left:1.27cm;">Wheelbase: 3,409mm (134.2")
<p style="margin-left:1.27cm;">Front legroom: 1,064mm (41.9")
<p style="margin-left:1.27cm;">Rear shoulder room: 1,372mm (54.0")
<p style="margin-left:1.27cm;">Engine bore x stroke: 95.5mm x 101.6mm (3.76" x 4.00")
<p style="margin-left:1.27cm;">Turning radius: 6.7m (21.9')6.7 m
<p style="margin-left:1.27cm;">Front shoulder room: 1,382mm (54.4")
<p style="margin-left:1.27cm;">Front hiproom: 1,369mm (53.9")
<p style="margin-left:1.27cm;">Towing capacity: 1,996kg (4,400lbs)
<p style="margin-left:1.27cm;">Front headroom: 1,034mm (40.7")
* While every reasonable effort is made to ensure the accuracy of these data, we are not responsible for any errors or omissions contained on these pages. Please verify any information in question
2010 H3T for sale - SOLD
- normsadler
Norm & Sue
2010 White H3T (sold)
- Beets
Re: 2010 H3T for sale - SOLD
Sorry to see you are selling her but glad your keeping the H2 looking forward to some trails soon
[center]REMEMBER:[/center]
- normsadler
Norm & Sue
- normsadler
SOLD!
A big thanks to Serge at <a href="http://www.favoritmotorscanada.ca">Favorit Motors </a>for helping to sell the truck. He kept it in his indoor showroom for two months and found the right buyer and the right price. Serge took care of everything for us and closed the deal. Thanks Serge!!
The new owner is having it shipped to Alberta!
Norm & Sue
Well done Serge!
Sorry to see it go Norm and Sue...
- Sub
no problem! glad it turned out well!
