1999 hummer h1 soft top
- 94redklzese
I'm selling my 1999 hummer h1 soft top, it has 140000 miles. This h1 is very well maintained except it needs a paint job. It has been my everyday driver since 2007, the body has some major oxidization but its not like it cant be fixed. I have lots of spare parts 3 sets of wheels 1 GSAs 2 37 inch coopers and 3 some bridge stones. The abs and tt4 lights are on but that is because a sensor needs replacing. The truck comes with 2 12inch jbl subs with and Boston higs and mtx mids. It has been updated with a new injector pump in the spring, it has a rubber duck pmd, it has marine injectors, new bosch glow plugs, controller. Engine oil changed every 4000km, Lucas oil in hubs, synthetic in transfer case changed every spring, transmission oil changed in spring also. Ac does not work but I do have the hose that needs to be replaced in order to work. It has a new oil cooler, power steering cooler and power steering box has been reinforced from both sides of the frame. I have all new ball joints upper and lower not installed but the ones on the truck are still fine. It has a 4 inch exhaust. I have lots of spares like Brake lines tools like hub seal tools, coolant was flushed every 2 years with distilled water. I don't want to sell it but I work far now so I don't drive the truck as much as I would like. I'm asking $35000 or $47000 with a new paint job.
- mukwa
Re: 1999 hummer h1 soft top
Is it still for sale and where are you located?
Located in Mississauga , you may want to pm him as he has been offline for more than a year
