Help! My PM is not working
Need a bit of help on how to navigate around the forum or some questions? This is the spot, we will try to guide you in the correct direction and if you have an idea for the site, drop a note too.
citiboy
Post by citiboy »
Member's can't PM me.....anybody know how to fix or enable this Image?
Thanks
<div> </div>
Archngel
Re: Help! My PM is not working
Post by Archngel »
[quote name='citiboy' timestamp='1346089046' post='39863']
Thanks
Looks like your box if full,, clear or delete content in your inbox
citiboy
Post by citiboy »
[quote name='Archngel' timestamp='1346093933' post='39865']
Marc, i can't even access my inbox Image.
<div> </div>
I will check Jimmy...
you are all fixed, you were over your message quota...keep an eye on it next time..but it should work now...
citiboy
Post by citiboy »
[quote name='dwaxman1' timestamp='1346682471' post='39940']
Derek, many thanks Image.
<div> </div>
