How to add your Avatar
Need a bit of help on how to navigate around the forum or some questions? This is the spot, we will try to guide you in the correct direction and if you have an idea for the site, drop a note too.
Locked
njlondon
Post by njlondon »
To add an avatar follow the steps below:
Sign into the Forum.
On the upper right of the page is your user name.
From the drop down menu select My Profile.
From the About Me tab, click on Edit My Profile.
Then select Avatar from the menu on the left.
From here you will able to browse to the image on your computer you wish to use as an avatar.
Locked
