CTIS
ucana422
CTIS
Post by ucana422 »
Have checked fuses and relay,.yet after  (sadly) a trip to the mechanics my ctis still seems to be getting no power ,. ;^( ,.any tips?
Re: CTIS
DOES THE COMPRESSOR TURN <img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' />
Re: CTIS
There is 2 fuses for the ctis, fuse box inside  and the 30amp engine compartment fuse. if it was the interior fuse, your solinoids are getting old/sticky.bump this one up for testing--15a,  if the exterior, then best check the compressor for shorts.
You can direct connect the compressor to power to test if the compressor is good or not.--short run test only--booster cable from battery to post on compressor
start from here and we can help further once this test is complete..
one thing to keep in mind. compressor could be frozen due to condensation, mine does not like the winter
