Looking for a set of new bolts and Nord-lock washers for my truck.. anyone know of a good place to get them??
Roy, you have any in stock??
Nord-Lock washer and New Half shaft Bolts
- Darcy
Re: Nord-Lock washer and New Half shaft Bolts
fastenal dude any nut and bolt place should sell them
- Tom
Roy has a bunch in stock, he's got the right bolt with a nice lip on it that will hold the nord lock really well.
- paulg
blue hummer outfitters sells a replacement set that use locking tabs and are reusable.
http://www.bluehummer.com/lohabokit.html
[center]Lifes a bummer if your not driving a Hummer...[/center]
[left]2001 black HMCS
40" XTerrains on 17" 2 piece Hutchinsons with Beadlocks
3" bodylift
Heath Programed ECU
Heath Manual wastegate controller (turbomaster)
Walking J feed the beast Fuel line upgrade
Remote PMD
CMGS water\meth injection
Rear head cooling kit
Provent 200 Oil Vapor seperator
Scangage II
Boost, EGT, Temp gauges.
Dynamat extreme
dual optima red tops
Straight piped exhaust[/left]
3" bodylift
Heath Programed ECU
Remote PMD
Scangage II
Dynamat extreme
[quote name='dwaxman1' timestamp='1306435056' post='27872']
Yes keep in stock, about 200 pcs of each!! <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Thanks Roy, Got them from Markus last night!
