07 H2 front Heated Seats
BigDawg99
Post by BigDawg99 »
My heated seats just stopped working..i went to class and they were working..cold night,,i head back home and they didnt want to turn on..I was looking through my manual and couldnt find the front heated seats Fuse Location..i found the IGN Rear Heated seats...is there a fuse for the front heated seats..and if so..where is it located...thanks for any info you can give me...much appreciated
When People are Running out of a Burning Building..I am usually the one Running In...
Im a Volunteer Fire Fighter
BigDawg99
Re: 07 H2 front Heated Seats
Post by BigDawg99 »
and i just noticed that the seat wont even move..power seats aint working also..i have been trying to decipher the Fuse location Manual and cant seem to get an understanding on which fuse i need to check or relay to check...if someone can point me in the right direction..would greatly appreciate it..
Gadgets
Post by Gadgets »
OK, I am not 100% sure about this, however after looking over the electrical diagrams I'm pretty sure you are looking for the:
INSTRUMENT PANEL RELAY BLOCK
NOTE: Instrument panel relay block is located at lower left corner of instrument panel.
See Fig. 7 .(in the attached pdf)
Check the CB 30A SEAT fuse (or circuit breaker) in the lower left corner of this block as seen on page 2 of the attached pdf.
Hope it helps
Brian
<p class="bbc_center">
normsadler
Post by normsadler »
Check the large electrical connectino plug beneath the drivers seat. When my heated seats stopped heating and moving, I could wiggle the plug a bit and they would work. After a while, I pulled the plug apart and noticed that the large power and ground connections had corroded and shorted, melting the connector. I bypassed the connector for these two wires, and have not had a problem since. Hope that helps (or hope that isn't your problem). Good luck!
Norm & Sue
2010 White H3T (sold)
Indy
Post by Indy »
Good luck finding the problem. Heated seats are probably one of the best inventions for winter driving. First thing I do when I set of on a cold morning is to make sure my bottom gets nice and warm <img src='http://www.canadianhummerclub.com/forum ... rgreen.gif' class='bbc_emoticon' alt=':mrgreen:' />
Ferrari Mondial 3.2 Cabriolet
Jeep Grand Cherokee 5.7 Hemi
99 HUMMER H1 HMCS / bright white / P400 6.5TD / heavily modded - sold
VIPER RT10 GenII / silver - graphite stripes - sold
FJ Cruiser / sun fusion yellow / "C" package- sold
HUMMER H2 / yellow / Adv. package / 4" lift / 37" STT - sold
Plymouth P R O W L E R / red - sold
Corvette C5 / Millennium Yellow / 6M - sold
Corvette C5 / Nassau Blue / 6M - sold
J E E P ZJ / 7" lift / white / 35" Cooper STT - sold
J E E P TJ / 7" lift /chillipepper red / 37" MTR - sold
Mustang GT 4.6 / black / 5M - sold
BigDawg99
Post by BigDawg99 »
Thanks guys...your help is much appreciated...i will get under the seat tomorrow and try pulling those plugs apart to see if anything helps..i have checked the CB seat 30a fuse and tried another one and it didnt work..i am going to take a good look tomorrow morning and if i find a result to my problem..i will come back and post what i find..
BigDawg99
Post by BigDawg99 »
went to my truck today and started looking at the wires below the seat...i pulled on a set of wires and the heated seats started working and so did the power seats..thanks for everyones help..now i can go have a weenie roast everytime i go for a cruise..
normsadler
Have a close look at the connector and make sure the wires are not corroded or arcing, Dont want a fire under there!
Norm & Sue
BigDawg99
Post by BigDawg99 »
will do..thanks for the heads up..
