Car Dolly
Boeing Jet
Car Dolly
Post by Boeing Jet »
Hi ALL
On the 19th I'm heading to Montreal for the Rally. I will be towing a car on the way to get it Quebec plated. I have 2 questions and looking for some assistance.
1. I have the use of a friends trailer (2 axles) which has an out-dated inspection sticker. The trailer is for personal use and registered as such and has an Ontario plate. Does it need to be inspected?
2. In the event the trailer is not use-able. Does anyone have a car dolly i can borrow for the trip?
The vehicle getting towed is a 2001 Neon by a 1999 H1 wagon.
Thank you ALL
Re: Car Dolly
[quote name='Boeing Jet' date='10 May 2010 - 09:04 PM' timestamp='1273543465' post='16714']
Hi ALL
Thank you ALL
YOU CAN GET ONE FROM UHAUL ONE WAY ....NOT TO MUCH $$$$
Boeing Jet
Re: Car Dolly
U-Haul has them for 45$ a day. If I drop it off in Montreal it's 105$. So either way it'll be about 250.00
Re: Car Dolly
[quote name='Boeing Jet' date='11 May 2010 - 06:29 PM' timestamp='1273620588' post='16769']
MAYBE TAKE IT TO GO BACK ...I AM SURE YOU CAN PULL SOMEBACK AFTER THE RALYYYYYYYYY <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
Re: Car Dolly
[quote name='T.C.' date='11 May 2010 - 10:00 PM' timestamp='1273629601' post='16789']
I got one to pull back, a M35 from Montreal!! If you are up to it!!!! <img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' />
Boeing Jet
Re: Car Dolly
If you have the M35 ready to go, I'll put my H1 on it and tow the little one behind.
