Hi,
I need mounting brackets for the newer style of brushgurds.If some one has as set they don't need, please let me know.
Thanks,
Martin
Brushgurd Mounting Bracket Needed
- 98hmc4
Re: Brushgurd Mounting Bracket Needed
[quote name='98hmc4' date='05 June 2010 - 07:50 PM' timestamp='1275781826' post='17921']
Hi,
Thanks,
Martin
These are just 1*2 angle with 4 holes in them. TC not send them???Maybe pm the big guy and inquire.Now he may of needed these to mount the new bushbar.You may need to make a run down to the shop soon. Probably see you soon! <img src='http://www.canadianhummerclub.com/forum ... feSpit.gif' class='bbc_emoticon' alt=':coffeespit:' /> <img src='http://www.canadianhummerclub.com/forum ... lleyes.gif' class='bbc_emoticon' alt=':rolleyes:' />
Hi,
Thanks,
Martin
[quote name='Roy' date='13 June 2010 - 02:05 PM' timestamp='1276455916' post='18175']
YES I USED THE M FOR THE NEW ONE ...I HAVE TRAVIS LOOKING FOR 2 ...HE SHOULD LET ME KNOW THIS WEEK!
[quote name='T.C.' date='13 June 2010 - 06:31 PM' timestamp='1276468304' post='18182']
Will not cost that much to make new ones,Could be done before Travis has a chance to look!!As well as the delivery cost!!!
Besides, need Martin in the shop for some pressure sales! <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' /> <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
- 98hmc4
I thought it is a couple of pieces for each side. I told in earier years the brackets were one piece but now are two. The peices I would need are number 5,7,13 and 14.
[quote name='Roy' date='13 June 2010 - 07:23 PM' timestamp='1276474992' post='18188']
I NEW YOU CAN DO IT <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> 98HMC4 WILL BE HAPPY
