Parts For An H1
Re: Parts For An H1
Contact Roys, he can probably get you some parts!
njlondon
Re: Parts For An H1
Post by njlondon »
[quote name='dadshumm' date='19 July 2010 - 07:08 PM' timestamp='1279580912' post='19507']
i need for a H1 breaks, roters, clutch pan, front and rear coils and shocks, also factory rims and some tires. run flats for sure.anyone got a line on that sort of stuff?
Why would you want run flats?
They are problematic, make tire changes tough, and personally if they were on my truck I would take them off and discard them.
Oh yeah, that's right, I did do that.
Unless, of course, you are planning to go to a war zone.
Beadlocks are a different story.
Just asking.
Re: Parts For An H1
have a set of runflats.
I believe Roy at www.crazycanucks4x4.com will hdoes have all the rest...and maybe even a set of runflats too...
if not www.hummerpartsguy.com has all of it..
abot
Re: Parts For An H1
Post by abot »
[quote name='dwaxman1' date='19 July 2010 - 09:24 PM' timestamp='1279589056' post='19510']
I came across this on eBay, and it's worth a look if you need a laugh:
2 Piece Runflat
Alan
"Lead, Follow or Get Out of the Way"
General George S. Patton
92 Softtop, 97 Wagon, 68 Stalwart, 87 Pinzgauer, 62 Haflinger, 44 Willys MB
njlondon
Re: Parts For An H1
Post by njlondon »
[quote name='dadshumm' date='20 July 2010 - 12:25 PM' timestamp='1279643149' post='19531']
i got a set of beadlocks on their now but just a set of cheep all terain tires. looking for something with a little more meat and grip for the trails.would like the run flats just for the reason i dont have a spare rim or tire to go with my ctis system. figured that would be a better way.also would like the original rims because they got the ctis protective cover on the rims.
That's not a good solution.
You should know that if you go flat in a tire, and depend on the run-flats to get you any distance, you will destroy the tire.
The military doesn't care. Someone may be shooting at them.
Much better to get a spare rim and tire.
Re: Parts For An H1
i need for a H1 breaks, roters, clutch pan, front and rear coils and shocks, also factory rims and some tires. run flats for shure.anyone got a line on that sort of stuff?
Yes ,I do have all in stock except, tires and rims, But I know where to find a set of 16.5 split rims w/GSA at 30-40% tread.
Re: Parts For An H1
[quote name='dadshumm' date='22 July 2010 - 02:24 PM' timestamp='1279823071' post='19596']
sounds good. what would that run me?
Check out my site for all the individual parts, Tires and rims, have to verify,but around the $600.
As stated earlier, I have all your parts needed in stock. <img src='http://www.canadianhummerclub.com/forum ... /wavey.gif' class='bbc_emoticon' alt=':wavey:' /> <img src='http://www.canadianhummerclub.com/forum ... /wavey.gif' class='bbc_emoticon' alt=':wavey:' />
