Have just purchased a couple of Rugged Ridge 10500# winches.Need to have them tested. Will supply at a very reasonable cost. Please let me know.
<img src='http://www.canadianhummerclub.com/forum ... adbang.gif' class='bbc_emoticon' alt=':headbang:' /> <img src='http://www.canadianhummerclub.com/forum ... adbang.gif' class='bbc_emoticon' alt=':headbang:' />
Specs.....
#15100.01 -
HEAVY DUTY 8,500 LB OFF ROAD WINCH, RUGGED RIDGE
Durable. Tough. Affordable. The Heavy Duty 8500 LB Winch from Rugged Ridge is everything you could want in a winch. It is driven by a durable 5.5 HP Series Wound motor for long life and extra pulling power. A tough 3 Stage Planetary Gear box with a 172.8:1 gear ratio delivering power, and reliability on each and every pull. The Heavy Duty 8500 LB Winch has more power and exclusive features than any other winch in its price range: Stainless Steel Hardware- All the exterior winch body screws and bolts are Stainless steel to prevent rust and provide a long life. All Rugged Ridge steel cable style Winches include off road light mount roller fairleads allowing for the easy mount of two off road lights! Special Solenoid mounting brackets allow for multiple solenoid mounting points and the ability to tilt the Solenoid for ease of use. This “tilt” feature ensures that each Rugged Ridge winch can be used with almost all off-road bumpers and over riders! Limited 2 year warranty against manufacturing defects (1 Year on electrical). Each winch has been independently tested to ensure they meet or exceed all specifications.
#15100.10 -
HEAVY DUTY 10,500 LB OFF ROAD WINCH, RUGGED RIDGE
Lightweight. Durable. Tough. Affordable. The Performance 10500 LB Winch from Rugged Ridge is everything you could want in a competition winch. It is driven by a durable 6.6 HP Series Wound motor for long life and extra pulling power. A tough 3 Stage Planetary Gear box with a 218:1 gear ratio delivering power, and reliability on each and every pull. The Performance 10500 LB Winch has more power and exclusive features than any other winch in its price range: Stainless Steel Hardware- All the exterior winch body screws and bolts are Stainless steel to prevent rust and provide a long life. All Rugged Ridge synthetic rope style Winches include hawse fairleads. Special Solenoid for ease of use. This “tilt” feature ensures that each Rugged Ridge winch can be used with almost all off road bumpers and over riders! Limited 2 year warranty against manufacturing defects (1 Year on electrical) Each winch has been independently tested to ensure they meet or exceed all specifications.
We also have these winches available with synthetic rope instead of steel cable.
Add about 200$ for synthetic
8,500lbs. #15100.02 -
10,500lbs. #15100.11 -
Winch tester Needed
Winch tester Needed
Re: Winch tester Needed
Hey Roy,
Any chance you can get some Recon 17500lbs winches??? Dan (Threeman) and I (PolarBear) are planning toward this purchase soon so if we could get a better deal all the better!!!
[quote name='Polar Bear' timestamp='1293132321' post='23857']
Hey Roy,
Was not Tony the Caboose working on this??? <img src='http://www.canadianhummerclub.com/forum ... ngHead.gif' class='bbc_emoticon' alt=':banghead:' /> <img src='http://www.canadianhummerclub.com/forum ... ngHead.gif' class='bbc_emoticon' alt=':banghead:' />
Hey Roy,
- duncanpa
[quote name='Roy' timestamp='1293126193' post='23856']
What's the deal Roy???
Hey Patrick, this would be a GREAT Winch for You!!! It already comes with Synthetic rope!!
http://www.ruggedridgeoffroad.com/synth ... inches.php
I looked through the info and it uses the T-MAX Sealed Solenoid so that is really good!
I can't find the Hp specs for the motor nor the gearing...Roy any ideas as to those specs.<img src='http://www.canadianhummerclub.com/forum ... #>/huh.gif' class='bbc_emoticon' alt='???' />?
I just found the specs. 6.6Hp motor and 218:1 gearing, that means that it is a rebadged T-MAX like mine...in that case this thing will be AWESOME!!! Mine has fast line speed and super pulling power so now this is a REALLY GREAT DEAL!!!
Oh and it also has a 3 year warranty!!!
Just Thought you should know!!!
Hey Roy,
Shipping for the Recon is about $150 plus border stuff.
Hey Roy,
[quote name='duncanpa' timestamp='1293142502' post='23862']
Deal?? Just making sure these are tough enough to stock in the shop.No sense having a "will order in business" .I keep in stock!!
I believe I have the 2 testers.
Now, if what Kev says is true, anyone else want a 10500# winch :
w/Steel cable for UNDER $650 or
w/Synthetic rope and fair lead Under $850 Canadian.
<img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' /> <img src='http://www.canadianhummerclub.com/forum ... /blink.gif' class='bbc_emoticon' alt=':blink:' />
- Archngel
Can any of them be fitted on a H3 without major transfo, I like the permanent behind bumper setting, but if a removable setting like on the H2, I'b interrested.
