________________________________________________________________
2-Way Radios:
2 way radio means any wireless radio device that both sends, and receives transmissions (2 ways)
the standard bands are:
HF(High Frequency): an old technology, with many issues due to interference and signal loss over distance, can be found from 3-30MHz. CB(Citizens Band) is part of this, and is lowest and oldest band of radio commonly used, 40 channels with a range of 26.964MHz to 27.405MHz
VHF (Very High Frequency): a commonly used radio frequency for construction and communication, not used often for personal communication, frequency range is 30MHz to 300MHz this allows for many more channels without as much interference. Radios are typically found from 136MHz to 174MHz
UHF (Ultra High Frequency): a newer technology using extremely high frequencies that travel long distances and around obstacles quite well, this band also incorporates the FRS and GMRS ranges, UHF can be found from 300MHz to 3GHz (3000MHz) typical UHf radios are found between 400 and 480MHz
FRS (Family Radio Service): a band of radio used within the UHF band, allotted for recreational use, the band is low powered and has limited physical range, UHF radios can communicate with FRS radios, provided they use the same frequency, 14 channels (not including privacy codes) and are limited to 0.5W transmit power. Frequencies are from 462.5625MHz to 467.7125MHz
GMRS (General Mobile Radio Service): very similar to FRS, share 7 channels with FRS, are allowed up to 5w of power, and are found between 562.550MHz and 467.725MHz. GMRS channels are used with a repeater, which allows the signal to be even stronger over distances GMRS channels are also found in the UHF range
there are other bands/ranges that i don't know enough about to explain, but are not prudent to our conversation, and not typically used for what we would be using them for...
UHF is by far the most versatile of all of the bands, as it incorporates GMRS and FRS channels, and have strong transmitters. ALL bands listed above, with the exception of FRS frequencies require an industry Canada (IC) license, or FCC license, however i do not know what, if any enforcement there is for radio usage, i will not support or suggest anyone does use anything without the proper permits or licenses
because the FRS radios are limited to 0.5W of power, their transmit distance is significantly lower than VHF, UHF and GMRS radios CB are higher powered than FRS, however with the low frequency, the signal does not penetrate as well. The higher the number is, the longer the physical wave is, CB signal's wave is approximately 12 feet long (if i'm wrong, someone please correct me) this wave is easily lost behind obstacles. Think of it as rocks, UHF (300-3000MHz) are tiny rocks, try to shoot a load of gravel with an air gun, now try to shoot a boulder (cb with 27MHz) with the same amount of energy... doesn't go as far..
If you are seriously interested in it, wiki can explain it much better than i can, if you want the best possible setup for what we would use, get a CB installed in your truck, and buy a dual band radio, these work in both VHF and UHF ranges, though don't expect them to do 30-3000MHz, as most anything above 480 isn't used by any conventional radio, it is merely still classified as UHF, your typical VHF radios will have a range of 136MHz to 174MHz, and even a dual band will probably have a break in their range, from 174 to 400, what IS in that area, i do not know...
to end it off, i recommend either a dual band radio, or a UHF, and with those radios, using the FRS frequency range, a list of frequencies/channels can easily be found on google or wiki, to tell you the license free channels for your radios
Why CB Radios sometimes have dead zones
Basically if you are at location X, you get reception... however if are between the signal valleys you can actually be in a dead zone even if it is just 25 feet away.
