Who has one?? I hear that these assist in lowering the overall temp but 60+% as it directs the air directly on to the Rads..opinions? Is this better the the electric fan options that some install?
Also Not sure about the look, thoughts on that as well??
H1 Predator Hood Scoop
- Sub
Re: H1 Predator Hood Scoop
[quote name='dwaxman1' timestamp='1302549327' post='26879']
I AM DEBATING....ITS UGLY <img src='http://www.canadianhummerclub.com/forum ... >/cool.gif' class='bbc_emoticon' alt='8)' />
- hameee@hotmail.com
When I put on my d-ring brush bar, I'm going to install two wind deflextors. Just two thin pieces of metal welded between the bars that run up to you d-rings. I'm sure they can also be clamped on and even use aluminum or stainless if you don't want to weld to a already nicely painted brush bar.
Either way the electric fan would cool better as they cool whenever you rig reaches a certain temp, the scoop or deflectors only cool at high speeds but that's usually when you need it.
i hate the look <img src='http://www.canadianhummerclub.com/forum ... adbang.gif' class='bbc_emoticon' alt=':headbang:' />
- Tom
Do not alter your factory cooling system. It is designed this way for a reason.
No electric cooling fan will match the factory fan's capability. It will only help the AC cool better at low speeds, but will actually restrict air flow at high speed. There has been extensive testing done on the hummer network forums.
