Water leek
Fantome
Water leek
Post by Fantome »
I noticed a leek under the front end on the passenger side. I got under the truck to find were it came from and I saw it from a bushing on a shaft witch links to the table suspension and runs to the middle of the vehicule. The shaft was kind of hot. Is there something inside that shaft? I have to say that my AC is not in function when it leeks. Does anyone know what I am talking about?
Sugarphreak
Re: Water leek
Post by Sugarphreak »
Not to worry, this is pretty common.
Basically when your AC unit is running (either for air conditioning or defrost) it will get condensation on the pipe and drip water underneath. Everybody has seen the water puddle under the car at one point and thought it was a leak!
Fantome
Re: Water leek
Post by Fantome »
[quote name='Sugarphreak' timestamp='1306243556' post='27821']
Yes when the AC is running but it leeks and I have not used my AC yet and no defrost in weeks!
Sugarphreak
Re: Water leek
[quote name='Fantome' timestamp='1306256689' post='27827']
Keep in mind that even if it is on the winshield air setting the AC unit will run automatically
Fantome
Re: Water leek
Post by Fantome »
[quote name='Sugarphreak' timestamp='1306259649' post='27829']
OK, thanks!
