Hey Marc, lucky you weren't there...otherwise you'll be in million pieces too
yeah ok I see it, no back draft, no shock wave on CB antenna, nor in tree leaves, hard piece of shrapnel coming from MUD yeah right, and debris sitting on top of the high grass, and no panic showing on whom ever was on the left. Very Nice effect, if I didnt stop to watch frame by frame i would have never seen it. <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' /> <img src='http://www.canadianhummerclub.com/forum ... ght_on.gif' class='bbc_emoticon' alt=':right_on:' />
Nice pics guys!!! Looks like a real blast!! I wish I had room like that!!!
Kev - that was very nice of you to help out that stuck H1! Way to go!
Actually when Roy's right front everything exploded...I did winch him out! Yes Roy's Big Beast Exploded the lower ball joint, upper ball joint, half shaf, tie-rod end, and twisted the steering box shaft!
The polarbear playground bit him hard!
Yes maybe bringing the whole family and the tractor trailer cuz I have to pick up my trailer at leahy.but we should be there just for the afternoon . Is it okay for you?
And how long did it take for you to get Roy's Hummer back onto the playground???
Was able to put her back together that afternoon, play some more , drive to resting place, then go out the next day. It all happens when you winch 48" straight wall of a river bank.O'well, live and learn more.
