Snatch Blocks
A more general area for members only, like your local "spot" lets chat about truck stuff or anything that is bugging you or share something..
Gadgets
Snatch Blocks
Post by Gadgets »
I am wondering about Snatch Blocks. Knowing they can double the capacity of a winch, how do you determine what load rating to get. Do you go by the max pull power of the winch, the approx weight of the vehicle (with added load for being stuck etc). ARB's website doesn't even give a load rating on their's which I thought was odd. So I'm asking here. I would like to pick one up, but want to be sure I am getting the right one.
Thanks guys
<p class="bbc_center">
Re: Snatch Blocks
[quote name='Gadgets' timestamp='1351649457' post='40730']
Thanks guys
Ideally due to the loads that are going to be exerted on it I would highly advise the biggest one possible. As well, you need to pay equal attention to working load and breaking strength along with what cable size it is designed for. I use ARBs 9000kg one. It is super smooth and probably one of the fastest and easiest pulley blocks to set up during rigging.
Here are the specs for it; http://www.vikingoffroad.com/products/A ... Block.html
Btw, you can get this Pulley block from Roy or TC, I am sure they both have it in stock!
http://www.crazycanucks4x4.com/?p=ordr& ... prod&id=92
or
http://www.crazycanucks4x4.com/?p=ordr& ... prod&id=45
And just so you know, yes it will double the pulling capacity of your winch it will also reduce the line speed to half. However, when you are pulling close to maximum load with only your winch, it is not fast at all! With the pulley block, your winch will actually pull faster at full rated load than without! Why, no strain on the winch!! Also a pulley block gives you the magical ability to pull some one out while being parked beside them or perpendicular to them! Trust me we have done some amazing pulls all thanks to a Pulley Block!!
Hope this helps,
Hesh
Re: Snatch Blocks
Post by Hesh »
Also, be sure to keep in mind that some will work with both synthetic line and steel wire, but others will not be suited to both. If you have synthetic line, be sure to maximize and protect your investment and get a snatch/pulley block that is designed for use with synthetic.
Re: Snatch Blocks
I use the ARB209 with a 12000#winch. on the tractor, --black H1--
Yes have in stock. You could get it as a bonus if you get the boss moving!$$ <img src='http://www.canadianhummerclub.com/forum ... oflmao.gif' class='bbc_emoticon' alt=':rotflmao:' />
Gadgets
Re: Snatch Blocks
Post by Gadgets »
thanks guys, here is my setup:
- H2
- 12,500lb Winch
- 3/8" steel cable on the winch
So the ARB one should be good....
And Roy, he was with me in my H2 last week, and says "I can hardly wait to get the H1, it's going to be awesome" I glared at him.... and reminded him this nice H1 is sitting there waiting for him, all we have to do is go get it!!! <img src='http://www.canadianhummerclub.com/forum ... ngHead.gif' class='bbc_emoticon' alt=':banghead:' /> I got a "I know, I know I'm tryin' man" out of him. So I just keep poking him Image
