Rubber Duck Anniversary Off Roading Tenn.
Here is a great place to Post events in your Area!!
Re: Rubber Duck Anniversary Off Roading Tenn.
So far, a better turn out, 4 Canadian trucks and time still left to register.
Trying to get Kevin to bring to H2 out, Hopefully Markus,Chris, Andrea,maybe Liam,Paul (3 for 1 optical) will register soon.
There will be 2-3 trailered trucks going down ,so,if you did break, we can still get you home.
Sub
Post by Sub »
Im still ok so far for oct... will se what happens
Event is full according to RD website, last check over 60 trucks.  Check directly at RubberDuck for openings 513-899-1735
So what day are we heading down to Tenn.?
So far only 4 trucks, Roy,TC,Sub, and Canada1
I am more than likely heading down on Tuesday afternoon ,maybe early Wed., depending on if there is interest in a convoy.
Normal driving is 4 hrs per stop.( truck fuel stop for trailering trucks ) H1's can do an 8 hr run before fuel, but lets play safe just in case
Fueling stops....
full when leaving KW  area or equivilent distance
Bowling Green Oh  4 hr 3 min
Lexington Ky   3 hr 55 min
Clinton Tn    2 hr 24 min
Hotel          24 min
With stops an estimated 12-13 Hour road trip
If heading out on the 22nd, we should be on the road before 7am.
ONLY 4 trucks for this event !!!! Damm .....this will not happen again in a LONG time !!!! Maybe never!!!!!!
Sub
Post by Sub »
i will join the convoy if we launch around 8am...i dont have any cancelation changes, i am only sencitive to my passport, which i sent in for renewwal last week and i think it should be back by then, i will be trailerin also my 04 and hopefully no issues so far. Canada 1 , are you in ontario?
Sub
Post by Sub »
hotel booked.looking forward to meet my oldy grumpies Hummers soon!
Do not run a dealer plate across the border, could get interesting ,
if driving that ford, put some tires on the front end.
Tentitively,
we will be leaving London around 7 am. --12 hrs driving with stops.
May be heading out the night before if the other 2 are still in Florida.
canadah1
Post by canadah1 »
I am planning to come back from Florida then go on the Wednesday 22Oct14 to the event. Need to do some work before but that might change.
Sub,  I live in Newmarket so would be leaving 4:30am or so to meet up in London if the convoy is a go. If no convoy I would probably head down through Buffalo. Will keep you guys posted if any change in plans.
I spoke to Travis and he is now maxed out at 70 trucks and 160 people approx. "This is going to be crazy" I believe were his words. :smil9:
Cheers,
Tom
Ya 70 trucks in the back end of the hotel.
This will be a blast.
Its not just the trucks, but the trailers and rigs that pulled them as well.
It looks like the food places may be a bit busy a couple of nights.
I know there is one or two unregistered trucks that may come as well.
Travis also mentioned about some LIVE bluegrass as a good possiblity.
