39.5 Iroks, Torsen II's, 3.08's, RD gauges, Alpha panel
SELL Spare parts, OEM, After Market, what ever that is Hummer related and for your Trucks
hithere
Post by hithere »
Hi there,
I have 4x 39.5x13.50R17 Interco Radial Iroks that I am looking to upgrade to the 41x14.50R17 version. Tires have around 4000 miles on them. Around 3000 miles in 2013/14 winter rotated and <1000 miles in the 2014/15 winter (truck being built up). Entirely winter/cold weather driving and 99.9% on road use. Never seen Rock, Mud or Sand. Never a flat, never a cut, never a single issue. Balanced up really nice and I have been really impressed with them. I am looking at doing a custom bed rack and need the 5th tire, but I am leaning more towards the 41", so I thought I would check interest on here before Kijiji. Tires have very little wear and have worn very evenly. I am super impressed with their winter handling. That's why I am buying them again. I can measure tread depth and get photos soon. Looking for $1700. 4 new from 4 wheel parts is $2700 before tax.
I had brand new 3.08 diffs with Torsen II's. I then built up the differentials with Auburn lockers and 2.73 gears. Now The left over parts that I have are: 2x brand new Torsen II's for ABS model trucks, 2x brand new 3.08 Ring and Pinion sets and also the ring and pinion shim sets. Looking for: $550 for both 3.08 sets ($880 USD new), $1200 for both Torsen II's ($1800 USD new) and if someone needs shims let me know. I paid over $300 just for these shims.
I have 3 Rubberduck gauges, which I got for my truck and decided to go a different route. They are identical to the ones on their site here: http://www.rubberduck4x4.com/store/pc/Hummer-H1-Gauges-Monitoring-c99.htm
The gauges are the Boost, EGT, and Trans Temp gauge. The EGT thermo coupler is NOT included nor is the Trans Temp Sensor (RD sells them separate). I installed in my truck and all gauges work 100%, but I am doing something else. Once I had the sensors installed I never rebought them or took them out. These can be sourced elsewhere and aren't specific to the gauges. The Boost has all required parts. Looking for $140. Cost me $200 USD.
I have a 2" Alpha blockout panel for the rear bumper. I installed, used for a year, and redid a custom rear bumper that no longer requires the panel. Looking for $80. Cost me $130 USD.
If the prices are too much for you that's fine. I import my own parts, pay exchange and am in no certain rush to sell any of these parts. If these can help someone out getting a better deal then better on your truck then in my storage. I will get photos as I get the opportunity.
Re: 39.5 Iroks, Torsen II's, 3.08's, RD gauges, Alpha panel
You are in SK? Have to check freight on some of these parts
hithere
Post by hithere »
I am located in saskatchewan. If I have some flexibility I can ship out of yorkton sk. They have depots for jays and dhl. Others as well. Also open to trading for some 12ks people have lying around.
hithere
Post by hithere »
All 4 Iroks are measuring 18/32" or 9/16" tread depth. They all are very evenly worn and the Interco website claims 21/32" to be brand new depth. Photo shows 9/16" reading.
I have photos of all parts, but the forum won't let me post that many. You can text or call Kyle for more photos/info. 306.740.8437.
You can post that many, just have to down size the pixs
Sucks, I was looking for 39.5 couple months ago...settled for bias iroks.... wish I knew of those
hithere
Post by hithere »
For more photos check out the hummermarketplace.com. I posted those prices in usd. These are cdn.
drm
Post by drm »
I would be interested in trading for the 3.08 gears and shims. I have 4 brand new 12k rear axles so you would need a centering kit for the for the front diff. or you could just put 2 in the rear. if your interested let me know. thanks.
hithere
Post by hithere »
Give me a call or email me @ kyle.herperger@gmail....... I am interested in 12k shaft trades, am general tailgates in good shape or 41" iroks
hithere
Post by hithere »
Rubberduck gauges are sold. I am currently ordering 12k conversion so if any 12k trades please contact me ASAP. I am interested
