Ever since I've owed my truck I've always ment to grease those, but lol last on my bucket list...
I gotta break down , I'm sure it's an easy job
Steering wheel issue starting
Re: Steering wheel issue starting
- Skenth
Thanks for the tip.
Any pics of directions on where that joint is so I can try to lube it myself and see. Any particular grease to use. I have a grease gun and a basic grease.
I'll goto Roy's shop late may to get few minor issues checked out.
I had this happen several years ago.
Ended up being the intermediate steering shaft needs to have the joints greased from time to time.
The one under the dash is hard to get to so nobody ever greases that one!!
Sonny Kenth
96 Hummer H1 4 dr Hardtop w slantback
- ddgermann
You may be getting tired of my clips from the manuals but here is another one. It doesn't actually tell you how to lube the intermediate shaft as I expect the job takes 3 arms and a circus trapeze but here is what it looks like. I need to do mine too...
Look at this: http://www.redhummer.com/myhummer/steering_shaft/index.html
And this:
<b>Steering column:</b>
<p style="color:rgb(0,0,0);font-family:Arial;font-size:14.6667px;background-color:rgb(238,238,238);">The steering column (the steering shaft actually) has two u-joints in it. One is located a few inches from the steering wheel (under the dash). The other is located near the steering gear, under the hood (within about a foot of where the steering shaft passes thru the fire wall). The steering shaft also has a "sliding part" which allows the shaft to change length. This joint is located near the u-joint inside the truck, under the dash. Some, but not all, Hummers have a grease fitting here.
<p style="color:rgb(0,0,0);font-family:Arial;font-size:14.6667px;background-color:rgb(238,238,238);">Let me know how hard this was to do.
<p style="color:rgb(0,0,0);font-family:Arial;font-size:14.6667px;background-color:rgb(238,238,238);">Derek
And this:
- Skenth
I'll attempt it this weekend and let you know. Feel free to come over to my place if you want to get some grease on ya. I'm in milton
Sonny Kenth
- ddgermann
I would like to but I am in Brazil this weekend... haha
Producing some of that grease...
D
D
- Skenth
The greasing/access to the intermediate steering shaft wasn't too complicated. It didn't have much grease in the joint...so I lubed up both lube nozzles. I'll drive it a bit and see if it made any difference.
The wires under the dash was a spaghetti mess. Seems like prev owner did some mods and spliced into some wires under there (remote starter install???)
Sonny Kenth
Yup that would probably be it (remote start/alarm) mines a major spaghetti factory as well.. Like crazy
Outta curiosity when your trucks stopped/parked can you easily turn your wheels?
This is more so curiosity as mine been the same forever,.,
But from a stop I feel like it gets harder, then I roll a little and turns always easy,.. But always pressure from a stop..
Sometimes now I wonder if my pumps tired,.
- Skenth
I can easily move the steering while while at park. The issue I had was while driving at slow speeds I noticed the steering wheel felt harder to turn compare to before.
Sonny Kenth
- ddgermann
I just had a new steering gear and pump installed 5000Kms ago. Even now mine is hard to turn on asphalt when stopped. I will turn but you have to use a bit of effort. Once rolling even slightly it turns with almost no effort.
Thats on 40" Toyos.
Thats on 40" Toyos.
