Front drive shaft noise/banging
Re: Front drive shaft noise/banging
Awesome news, ya at least with tearing it right down, this make you more confident / and quicker for any future tear down,,,
As time goes on , lol in time you'll always have a seal here and there put aside, as soon as you think she's pererct ,lol a different seal goes,....
Shockley after a great deal of time I THINK I'm leak free,....
I just took a look at the photos, you do have rust pits in the raceway, Sometime you have time in the next year, I do recomend chaging the bearings
WolfinJeepsClothing
Post by WolfinJeepsClothing »
You are correct, but for now it is a hundred times smoother running than before I put in the shim you recommended. Which was just some scrap ducting I had. I need to order some shims, seals, and have a few wheel studs I would need to replace.
I need to do seals on the hubs and differential.... but first I want to do a fluid change on the other hubs and get a grocery list together.
I just spent close to two grand on the two Jeeps and have more work to do on them yet. And I need them to get to work to pay for the Humvee.....
Wolf
My Humvee is special, just like everybody else's.
1987 HMMWV M998
1997 Jeep TJ
2007 Jeep JKU
2005 Jeep ZJ
Previously had 1984, 1987, 1991 XJ, 1994 YJ and some others I prefer not to talk about....
